f-250 flatbed convertion
Old 07-18-2013, 09:41 PM
redneckandy814's Avatar
redneckandy814
redneckandy814 is offline
I am in the process of starting a 250 project and I would like some tips on building a flatbed, should I go with steel or aluminum, both are available t me for this bed also can aluminum be powder coated and the truck has 6ft bed frame is it possible to custom make the flatbed for 8 feet?
Old 07-18-2013, 11:49 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
Steel-cheaper, easier to weld but heavy weight wise.
Aluminium- lighter, more $$ and a little more welding skill required and the correct welder than can weld aluminium.
A flat bed is easy and if you build it yourself (have skills and welder) can be a awesome addition. Under bed tool boxes (front and aft of rear axle can be added ,custom headache rack/light bar.
Steel frame with wood planks, steel frame with treadplate, aluminium frame with treated lumber planks. Make some low profile stock racks for the side and a butt board.
Here is what is going on my F250, I took it off a F150 parts truck....the old pic was when I first bought it, way to big and to long a flat bed.
First getting it repainted, new fenders, outer grill shell, cab lights and slicking up the interior. Then maybe sale it, who knows???
If shopping for one remember most are built for rear duel wheel trucks.
Old 07-19-2013, 12:35 AM
spikinfool05's Avatar
spikinfool05
spikinfool05 is offline
its hard to beat a bradford built flatbed. built right and built in the usa with usa steel. i have one and it does everything i need it to do. i have had 2 round bales of grass on the back. for the cost i cant see spending the time or money to build one.
Old 07-19-2013, 12:37 AM
77&79F250's Avatar
77&79F250
Bet that Bradford bed was like $1000 +, aluminium ones are like 3000 and a Deweze are way up there too.
Old 07-19-2013, 12:58 AM
spikinfool05
yep it was over a 1000.
Old 07-19-2013, 08:36 AM
77&79F250's Avatar
77&79F250
You might be a redneck if you are rock'n a flat bed.....I'm good with that.
Love the brown truck with the rear winch.
Old 07-20-2013, 12:59 AM
brian1080's Avatar
brian1080
brian1080 is offline
I miss my flatbed, but I'll build another some day.
Old 07-20-2013, 07:59 AM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
treadplate
Hey Rich off hand do you know the thickness of your treadplate on your flatbed? I need to modify my fb ,remove the skin and i would like to go with treadplate.
Old 07-20-2013, 03:34 PM
impalaslayer's Avatar
impalaslayer
impalaslayer is offline
i went with an 8x6 sheet of .125, the sheet weighs like 300 lbs
Old 07-20-2013, 05:49 PM
lafermedavid
fb
thanks impalaslayer,my bed skin(just sheet steel) is I beleive 14g,I have to cut it down to 7x8-3,,,maybe i will just leave it as is and grind it down and primer and paint,,,,,I was thinkin of removing it but what a pita thanks
Old 07-20-2013, 08:37 PM
77&79F250's Avatar
77&79F250
I would guess 3/16....but not 1/8th".....
Old 07-20-2013, 08:41 PM
riverguideguy's Avatar
riverguideguy
riverguideguy is offline
flatbeds sux id rather have a real bed. just looks cooler
Old 07-21-2013, 12:35 AM
77&79F250's Avatar
77&79F250
And so does your one tailgate sided opinion......lol
Old 07-21-2013, 10:59 AM
lafermedavid
fb
I have always liked the cream colored bradford pickup,I beleive that young man lives in Wyoming or montana,it was his Grandfathers.I have always owned trucks since i was a young teenager,,but for a working truck you can not beat a fb,,,,naturally you love looking at factory bed with that nice looking Dent or Bump,,,but loading a load of wood or coal or stone its night and day,its part of survival 1/8 inch 3/16 hum,,,,,,thats why I wanted to remove my skin 14g is light although awesome under carriage
Old 07-21-2013, 12:50 PM
impalaslayer
with enough under support i see no reason to go thicker then .125, your just adding weight
Quick Reply: f-250 flatbed convertion
