hood wont open.... - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
hood wont open....
Old 07-18-2013, 07:48 PM
surreyboy surreyboy is offline
surreyboy is starting off with a positive reputation.
hood wont open....
hey every one , sorry if this is the wrong spot to post this....
today i pulled the hood latch to check the oil & the cable broke !!! can any one tell me how i can open the hood with out the cable ?? & also , any one know the part # for the cable ??
thanks every one , appreciate any comments or opinions ! cheers !
Old 07-18-2013, 08:04 PM
Mdt1992's Avatar
Mdt1992 Mdt1992 is offline
Mdt1992 is gaining momentum as a positive member of FTE.
i had it happen to me, i went through the grill and unbolted the latch from the radiator support, its tight in there but you can get them
Old 07-19-2013, 04:22 PM
ch88250's Avatar
ch88250 ch88250 is offline
ch88250 is starting off with a positive reputation.
I have been able to get in there on other cars and trucks and find where the cable attaces to the latch and either pull on the cable with needle nose vise grips or if the cable is broken there move the latch arm that the cable pulls..
Old 07-23-2013, 12:03 AM
Bird Hunter Bird Hunter is offline
Bird Hunter is starting off with a positive reputation.
Not sure of the part numbers but you can get a replacement from LMC truck. Good luck!
Old 07-23-2013, 10:02 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
I was just messing with my hood latch this weekend, so the mechanism is in my head pretty good. if the cable broke off inside the latch mechanism, you're gonna be stuck unbolting the mech from the radiator support like mtd said. I can't think of any way you'd be able to actuate the mechanism through the grill without a cable...
if it broke off from the handle in the cab you could grab that with visegrips, like CH says. Its probably broken in one of those two places rather than in the middle somewhere...
good luck!
Broken Hood Release Cable chadwj Explorer, Sport Trac, Mountaineer & Aviator 5 06-27-2007 12:53 PM
Hood Release cable ishamael69 Explorer, Sport Trac, Mountaineer & Aviator 3 08-09-2004 06:33 PM
Hood latch cable broke Capt Quahog 1997 - 2003 F150 4 01-03-2004 01:57 AM
Hood locks and cable release ivanribic 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-26-2003 09:36 AM
97 explorer hood wont open musclemaker Explorer, Sport Trac, Mountaineer & Aviator 1 08-11-2003 10:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
