Propane Injection: What Do I Need To Know?
Old 07-20-2013, 12:38 PM
El Camino Man's Avatar
El Camino Man
El Camino Man is offline
Hey guys. Im looking to upgrade the ol Stroker and squeeze some more power out of it. The engines coming out to fix some problems and going back in in hopefully not stock form (depending on budget).
I think I can plumb the propane myself without a problem. Will I need a custom tune to make it work or is it plug and play? And can it be installed to come on at the flip of a switch or will it need to run the entire time the engines running? I have zero experience with propane. Thanks guys!
Old 07-20-2013, 05:04 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
There are several ways to make good power out of a 7.3 A set of stage 1 injectors, t500 hpop and a good fuel system will make you good reliable power. Propane is called "Propain" for a reason... I highly suggest that you don't mess with it.
Old 07-20-2013, 05:39 PM
fordpride's Avatar
fordpride
fordpride is offline
I wouldn't bother with it.
If you want a little more power on a budget look in to water/meth kit
Old 07-21-2013, 12:20 PM
El Camino Man
Those two posts are enough to make me shy away lol. Thanks guys!
Old 07-21-2013, 02:41 PM
21411's Avatar
21411
21411 is offline
Seriously, me too. Penny Saved for injectors!
Old 07-21-2013, 04:49 PM
glovemeister
If you give Jim Rose over at Rosewood Diesel a call he can get you setup with injectors and you will find you don't need as many pennies as you think lol.
Old 07-21-2013, 06:57 PM
El Camino Man
130,000 pennies is a lot in my opinion lol. But money well spent!
Old 07-21-2013, 11:47 PM
glovemeister
Hahah around 50,000 pennies from Jim. If everything checks out.
Old 07-22-2013, 08:58 AM
El Camino Man
"If" lol. On Rosewoods site they say injectors hardly ever pass inspection lol
Old 07-22-2013, 09:29 AM
21411's Avatar
21411
21411 is offline
after 200,000+ miles of truly unknown diesel you have to assume the injectors will be a little beat up. then my fear is waking up the engine and surprising the transmission! they are very used to each other. i assume op is handling that separately.
Old 07-22-2013, 11:24 AM
El Camino Man
Its still under deliberation lol. Im stuck between keeping the auto and upgrading it or sinking several grand into a parts truck with a ZF5. I think in the end keeping the auto would be cheaper and less work but its sure fun driving a stick!
Old 07-22-2013, 01:25 PM
21411's Avatar
21411
21411 is offline
either way will be good, it's just that i'm a fan of preparing for the power rather than repairing the damage.
Old 07-22-2013, 04:51 PM
El Camino Man
^^^ You got that right. I HATE transmissions in every way, shape, and form. Theyre a HUGE PITA to take out, fix, and reinstall. Especially the reinstall... Id rather spend some cash and make sure the tranny up to par than have to take it back out in a couple weeks lol
Old 07-22-2013, 07:32 PM
fordpride's Avatar
fordpride
A built E40D will cost you 3-5k
Old 07-23-2013, 09:30 AM
El Camino Man
To have someone build it, yes. I plan on having my father-in-law do it so it "should" be a lot cheaper lol. I haven't priced parts yet
c mobley
09-07-2014 09:13 PM
rolltide3006
06-28-2010 03:57 PM
GUelkman375
1999 to 2016 Super Duty
07-06-2007 01:50 PM
eric777
12-08-2006 09:22 AM
caterpillar
07-02-2006 09:20 AM
Quick Reply: Propane Injection: What Do I Need To Know?
