another upfitter question.
Yes a newbie at these. According to the Body Builders layout schematic the wires for the upfitter switches are "Located behind upfitter relay box".
I found the pass through wires on the driver side near parking brake exactly where everyone said. But my question is....are these pass through wires different than the actual wires that are "located behind the upfitter relay box". Or are these one in the same and where my hot connection needs to be made.
Sorry for the question. I have founds tons of info on this site in reference to them, just not this question that came to mind. Thanks!!
icee
icee
The wires for the upfitter switches are different than the pass through wires. The upfitter wires are accessed by removing the relay box and fuse box located under the dash to the left of the steering column. Remove the trim panel, remove the fuse box and the wires are there. On my 05 anyway.
Brian
Brian
Brian
Brian
TheKid1
6.7L Power Stroke Diesel
12-10-2011 11:23 AM
