1979 crew 2wd to 4wd conversion - Ford Truck Enthusiasts Forums
Old 07-17-2013, 11:45 PM
vwman69 vwman69 is offline
vwman69 is starting off with a positive reputation.
I just bought a 79 crewcab 2wd I was wondering if I could just put the crew cab body on the extra cab frame I already have a 78 supercab 4wd that I'm planning on using as a donor. So the big question is do I have to stretch the frame or what would be the easiest (best) way to go?
Old 07-18-2013, 01:21 AM
armstrongz34 armstrongz34 is offline
armstrongz34 is starting off with a positive reputation.
What is the difference in the wheelbase of the two? If you wanted to make it look original then you would need to stretch the frame super cab frame.. But if I was you, I would get some measurements and shorten the bed accordingly.
Your other option would be to swap the 4x4 running gear under the 2wd frame. (Lots of work but probably more practical than stretching the frame.) both will involve a fare share of fab work
Old 07-18-2013, 05:08 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Is the crew cab a long bed or short bed?
Either way I'd put the crew cab cab on the supercab frame & shorten the bed. It's a bit of work and not for the novice for any means though.
Old 07-18-2013, 10:18 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
I think another site that begins with F and ends in ification has builders sheets or something like that that have all the frame specs. I found them for my 72 CC so maybe the SCAB's might be there also.
Old 07-18-2013, 11:41 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
CCSB=150"
SCLB=155"
So, if you swapped your CC onto a SC frame, a shortbed is too short and a longbed is too long. Not that it hasn't been done, however. Here's a sweet one:
77 ford crewcab • Projects - Images and stories, etc... • Old Ford Crew Cab Community
Old 07-19-2013, 12:30 PM
Link is bad.
Old 07-19-2013, 12:38 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
The whole site is down right now i think. I tried getting on a couple different ways but no go.
Old 07-19-2013, 04:38 PM
ok. Will just have to try back again later to look - thanks.
Old 07-19-2013, 10:05 PM
both are long beds I really want to keep it a long bed I am getting the truck tomorrow then I can measure up and see what would be the best. I'm thinking about stretching the frame as long as I beef up the section I lengthen. I should be able to cut from the 2wd frame and put it in my 4wd frame without to much issue right?
Old 07-24-2013, 01:56 PM
Personally I'm not a fan of frame stretching - or even frame shortening for that matter, unless it's on a truck that will be full caged from bumper to bumper & the cage will make up for any weakness caused by the frame cut.
There are guys who do it though and most of their trucks haven't broken in half yet. IF you decide you want to cut the frame make sure a qualified welder puts it back together & that the thing is properly fish plated & reinforced.
Old 07-26-2013, 09:07 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow crazyredneckanyhow is offline
crazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud ofcrazyredneckanyhow has much to be proud of
if your truck is a true 79 longbed 2wd then its alot easier to doa 4wd conversion usig the supercab parts than to do all the frame work. Im looking at making another crew purchase in the next couple weeks and i hope to do a writeup on it.
Old 07-26-2013, 09:56 PM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
yeah I'd agree with that, its not that hard to make a 2wd a 4wd, especially if you want to lift it up enough to clear the crossmember. Then its really easy...
standard cab and crew cab front mount location spacing Earnie Rosenow 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-10-2016 12:40 PM
4x4 conversion on a 2wd crew cab belshe92 1973 - 1979 F-100 & Larger F-Series Trucks 22 06-03-2016 02:19 AM
Is my 71 crew cab frame worth saving ralphatlarge 1967 - 1972 F-100 & Larger F-Series Trucks 9 11-30-2013 10:34 AM
1975 ford crew cab 2wd to 4wd!!! MDford 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-15-2013 01:19 PM
Frames from 73-79 msperlazza 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-18-2012 04:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
