77 Ranchero, 351M, what intake? - Ford Truck Enthusiasts Forums
Old 07-17-2013, 08:31 PM
Ketchacar22 Ketchacar22 is offline
Ketchacar22 is starting off with a positive reputation.
Have two Ranchero's, one a 75, 351W and the newest the 77, almost totally restored, but question for anyone.
Will a Holley Dominator 4 bl intake fit on a 351M?
Old 07-17-2013, 11:52 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Welcome to FTE.
Looking at Holley, Summit and Jegs, I do not find an Holley intake to fit anything other than a 302. Do you have a line on an intake that is supposed to fit the 400/351M?
Secondly, what for? The 351M has low compression that pretty much limits the performance potential to anything other a mild upgrades, and those require a cam change. If what I read is correct, the Dominator is a high end performance manifold, not something really usable on a 351M.
Old 07-18-2013, 10:01 AM
Not looking for high end performance, if I wanted that would just buy a crate motor and tweek it.
Picked up the Holley last winter, without doing research. It is for a 351 from the early days. Do to the 351M using 400 heads makes me concerned it would fit.
Old 07-18-2013, 11:15 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Passenger Car/F100/350 & Bronco: All 351M's and 400's came with 2V carbs.
Old 07-18-2013, 12:10 PM
Thanks, but I know that. What I am doing is putting a 4 bl intake and 600 cfm 4 bl on the car. Does a Windsor 351 intake work on a 351M motor?
Old 07-18-2013, 02:49 PM
You need to do a little more basic research.
--351W heads will fit only with substantial modifications, and this is generally not done. (351C heads to 351W had some following, but again, requires mods) And if you did, the 351W manifold would not bolt up without adapter plates due to the deck height differences between the engines)
--351M and 400 heads (and everything else except the crank and pistons) are the same.
If it is for a 351W, sell it.
Plenty of dual plane 4bbl manifolds for the 351M/400:
http://www.summitracing.com/search/m...lds-carbureted
Old 07-18-2013, 06:23 PM
Thanks, that was what I thought, but wanted a bit of input. My experience years ago was with 289 and 302's, so been 40 years and sort of lost, never played with the 351's as far as doing any mod's.
Guess I need to go shopping.
Old 07-18-2013, 11:24 PM
40 years ago I had a '65 Mustang with a 289. Those engines were 9.5 or 10 CR, depending on what you had. "Spirited" motors, my 2bbl with 9.5 CR would run to 5500 RPM with a slightly bigger 2bbl carb. (off a 390)
Those were the days.
Enter the 351M. My grandfather had one in an LTDII. It shifted at 3500 RPM at WOT. Low compression, weak cam, they are just a pooch. Add the cranky carb that Ford could never fix to his satisfaction....but I digress. It ran well over 200,000 miles in the hands of my careless and abusive siblings after we had to take old gramps off the road.....but I digress further.
You can wake your 351m from it's slumber with a cam and the 4bbl intake. IMO, even spending your money for you, that's as far as I'd go with a 351M. The real secret to "fixing" these motors is a 400 crank and a set of 9.3 or 9.5 pistons. The following links are all things 400/351M.
Good luck with your Rancheros.
Bubba's M-Block Ford V8 Workshop
M-Block 351M/400 Parts Reference
TMeyer, Inc. Precision Automotive Machining
'67 Ranchero bench seat ideas needed hotrodford87 Ranchero & 1961 - 1967 Econoline 2 07-25-2014 04:53 PM
64 Ranchero compatibility Q's lgyee4 Ranchero & 1961 - 1967 Econoline 3 01-18-2012 08:46 PM
78 Ranchero Parklamp lens 351stroker Ranchero & 1961 - 1967 Econoline 4 02-22-2007 07:42 AM
Will a 1966 Mustang rear working 66 Ranchero 50J03 Ranchero & 1961 - 1967 Econoline 1 10-14-2004 01:47 PM
351W Headers for '78 Ranchero?? stormr Ranchero & 1961 - 1967 Econoline 3 11-20-2002 07:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
