1987 E-350 Econoline fuse box diagram? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-17-2013, 08:25 PM
chronicnetpro chronicnetpro is offline
chronicnetpro is starting off with a positive reputation.
Cool 1987 E-350 Econoline fuse box diagram?
Picked up this van that the PO had gutted. I was going to put in some dome lights. Haynes manual useless, so ordered a Chilton's. In the meantime, thought I'd just toddle out there with my meter and fiddle. Found that there was 12v at driver's door with door open. So far, so good. Then I did a stupid thing: I was using an old tail light bulb in a socket as a "test light". Put it across the battery terminals to verify that it was working and "POP!". I think it was so old and crusty it just shorted. Blew the 30 amp fuse in the fuse box. I replaced the fuse. Now, no 12v to fuse box when connected to (driver's side) battery. I checked the only fusible link I could find, which was right above battery. I think I frapped something that feeds the fuse box. I have ordered an electrical manual off ebay. Also checked the motorcraft site, but they only go back to 96. If any kind soul has access to the fuse box wiring, or a diagram showing how it is fed, I would be grateful. Thanks,
Steve
P.S. Forgot to mention: I am the "oddball", as this is a 6.9L diesel.
Old 07-18-2013, 09:42 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It is feed by a fuse link coming off the starter relay battery side if you have a charge light.
If you have an ammeter then there is also another fuse link down on the fender below the blower motor.
Old 07-18-2013, 01:51 PM
subford, thanks very much!
I will check it!
Old 07-24-2013, 09:15 PM
No dome light, no dice...
I hate to admit it, but I'm about to send this thing to the crusher...
I got hayne's, chilton's, and electrical troubleshooting manual off ebay. The diagrams don't appear to be what I've got. The fuse box shown in manual not the same as mine.
I have checked all fuses and fusible links. I think. There was one fusible link on driver's side engine compartment above battery, and 7 on the passenger side near starter solenoid. All good. Still no juice to door switch, or to headlight switch, for that matter. I'm starting to get a feeling that I frapped something important, like the ECM (if it has one).
Old 07-25-2013, 07:39 AM
subford's Avatar
Did you remove the battery on the passenger side and look at the two or three fuse links low behind the battery?
Did you look at the three or four fuse links on the drivers side down near the steering column?
Old 07-25-2013, 08:10 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Helm (helminc.com) has new original FoMoCo shop manuals, has printed all of FoMoCo's literature since the late 1940's.
1980/89 Econoline fuse panels: 1984/87 is the same (E4UZ-14A068-A), but no other year is. Which years are represented in those gypo shop manuals?
1980/89 Ford truck parts catalog fuse panel (14A068) applications. E = Econoline.
Left (towards bottom of page): 1980/83 // Right: 1984/89.
Old 07-25-2013, 12:58 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
bill, as great as it is having the original books to look at, i have to say that there must be an error in the book - because my 87 has the old-style glass fuses, and i know many of them have the more modern blade fuses - which means a completely different fuse box.
also, its common for a given model of fuse box to be used on rigs with different accessories, and thus different fuse positions doing different things. we see it all the time.
some fords from this era had small writing on the fuse box to identify what a given fuse was for - IIRC it was written just above the fuse it was referring to.
Old 07-25-2013, 05:46 PM
Quote:
Originally Posted by joshofalltrades View Post
bill, as great as it is having the original books to look at, i have to say that there must be an error in the book because my 87 has the old-style glass fuses, and i know many of them have the more modern blade fuses - which means a completely different fuse box.
Read my post again. Where did I make any mention of whether the fuses were glass or blades?
I did not .. all I did was list the parts catalog applications for the fuse panels.
Here's a partial list of GLASS fuses (14526) for 1980/89 Econolines.
Old 07-25-2013, 11:21 PM
I know that most vans from our era had blades, I wasn't trying to say that you said anything wrong, merely that the books seemed incomplete since I know that both styles were used and couldn't be the same part number.
Old 07-27-2013, 03:39 PM
fusible link testing?
subford, thanks. I did not find any additional fusible links near the aux battery, and no fusible links near the steering column. I tested all fusible links for continuity with pins and a voltmeter and thought they were good. I learned from another poster on another forum that he did the same thing, showed continuity but still had a fried fusible link. As I have gone this far, I suppose the thing to do is replace all existing fusible links with new (and butt connectors, so they can be easily replaced in the future).
Old 08-02-2013, 02:49 AM
Mystery solved.... partially
Well, I kept scratching around and finally found a fusebox diagram that matched mine.
But my truck is an 87, and this fusebox is from an 88 Econoline. So I started thinking that maybe I've got some kind of "mid-year" mutant that is actually wired as an 88. That might explain why I'm striking out with the EVT manual. It doesn't match what I'm actually seeing. So... I've included this (page 38 INSTRUMENT ILLUMINATION).
Maybe some kind soul who has a EVT manual for an 88 can take a peek at it and see if it is different from mine. If so, I'll acquire the manual for an 88 and go from there. Thanks,
Steve
1987 E-350 6.9L Diesel
Old 08-02-2013, 07:54 AM
subford's Avatar
I have the 88 & 85 Econoline EVT manuals and the fuse box diagram in them do not match the above photo.
The page image page 38 you posted does match page 43 of the of the 88 Econoline EVT manual.
Also it does not match any of the fuse box diagrams in the 1988 Econoline large fold out diagrams.
But I think I did see something like that in a past someone posted while working on an Ford Econoline ex-ambulance.
Old 08-02-2013, 01:40 PM
Thanks, subford.
Based on that info, I will use the EVT I have and go back to searching for "hidden" fusible links that feed fusebox. I am missing voltage at fusebox (#2 for sure) and seeing weird voltage at door (like 8 volts).
Old 08-13-2013, 09:42 PM
Fuse box mystery SOLVED!
Thanks to all who responded, particularly subford, who tipped me to the fact that one of the fusible links fed the fuse box. I am going to post everything I learned during this little fiasco, so some other poor schmuck may be able to find the solution a bit quicker.
First, the PO told me this van had a bad glow plug relay. Hey, it's his van, he knows his vehicle, right? Wrong. It was a starter relay. To add to the confusion, if you go to autozone and try to pull up the glow plug relay, they will happily direct you to the wrong part here:
Duralast/Relay - Glow Plug (16126) | 1987 Ford E350 1 ton Van 8 Cylinders 1 6.9L Diesel | AutoZone.com
So, anyway, it's a starter relay. The old one had 3 terminals, the new ones have 4. Just use the two big posts and the "S" terminal. All the fusible links and battery go on one post, ONLY THE STARTER on the other big post. Why this matters: the bracket is a little different on the new relay, you have to revolve it 180 degrees. While doing that, I accidentally moved some wires. I couldn't remember which went to what post (but there had been more than one on EACH). Another poster in the forums said all fusible links and batt on one, only the starter on the other. He was right. During this process I found that one of the fusible links that feeds the fusebox had been on the post with the starter (???). Putting it in the right position got power back to the fusebox.
If you are in need of a fusebox diagram, you might check here:
Auto Fuse Box Diagram Car fuse box diagram, fuse panel map and layout
You might also search for the year before and after yours. I have an 87 Econoline, but the correct diagram was for an 88.
If you don't have one, the Electrical and Vacuum Troubleshooting manual (off ebay) is a pretty decent book, useful and cheap (about 10 bucks). The Chilton's and Haynes are useless. If you don't have an EVT manual, and are in a big hurry, you might check for a wiring diagram here:
BBB Industries - TSB's & Wiring Diagrams
If you are new to this vehicle (as I was) and still wondering where the damn glow plug relay lives, it's inside the cab, under the engine cover, located at back of engine. It looks like this:
http://shop.advanceautoparts.com/wcs...8_pri_larg.jpg
1987 Ford E-350 6.9L Diesel
97 expedition power windows/lock not working. SlabPloX 1997-2006 Expedition & Navigator 3 07-15-2016 11:07 AM
Parasitic drain ranger719 6.0L Power Stroke Diesel 16 02-01-2016 06:43 PM
Fuses blowing... very strange!! MS paint diagram 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 7 05-09-2015 12:44 PM
4wd question SilverSS 1997-2006 Expedition & Navigator 3 07-21-2014 03:48 PM
HELP! Electric power draw 4.5amp lostman 1999 to 2016 Super Duty 12 03-05-2010 09:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
