1996 F150 4.9L Cylinder 6 misfire
My truck had been throwing an 0420 code for about a year and I was just clearing the code. Then last month I was taking the thing from Milwaukee to South Dakota on a hot day last month.
Climbing the bluff on the Minnesota side of the Mississippi river, my daughter and I noticed the smell of melting plastic. Shortly thereafter, the check engine light started blinking. I pulled over and the code said that cylinder 6 was misfiring. Under the hood I found the top of the diverter valve was melted away as was part of the exhaust hose barb on the DV. I fixed the DV as best I could with some high-temp caulk and a piece of brass and we continued on, but the thing continued to misfire on cylinder 6 all the way out to SD and back.
Some Notes:
- It does not misfire when the engine is cold. Even after the thermostat opens, it does not misfire for several more minutes.
- It is not compression.
- I replace the plugs, wires, distributor cap and rotor. No effect.
- I checked the EGR valve by plugging the vacuum line to it. The truck threw an 0174 (fuel too lean) and a 0401 (DPFE) code but the problem persisted.
- I replaced the two upstream O2 sensors which seems to have eliminated the 0420 codes I was getting, but did not eliminate the problem.
- I replaced the defective diverter valve.
- I am getting spark at the number 6 cylinder.
Is the problem the injector? How can I test that? I have never had an engine-temperature-related problem with an injector before. Is that common?
I love this truck. When it is not misfiring is runs like the day it rolled off the factory line.
Some Notes:
It sounds like the ignition control module on the fender or the PIP sensor in the distributor. It could also be a vacuum leak, or the MAF sensor.
Check your fuel pressure. A lean condition will occur if the pump is weak, also it could be a bad fuel filter. I had this happen on my '96 with a 300ci six in it. The filter was full of rust and water, replaced it and my lean code and poor running went away.
dubbs2012
1983 - 2012 Ranger & B-Series
10-16-2012 05:57 PM
