Condensate from natural gas, anyone tried this in a diesel ? - Ford Truck Enthusiasts Forums
Old 07-17-2013, 05:06 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Was wondering about this as a fuel. Anyone have any ifo on condensate from a gas well ?
Old 07-19-2013, 11:38 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
I don't know much about it, but from what Wikipedia told me, it sounds very similar to gasoline -- and therefore, probably doesn't lubricate very well and detonates at a much lower compression ratio than diesel or diesel-like fuels.
I personally wouldn't use it, especially straight. You could use it to cut a heavier fuel like WMO, or something, and probably get good results.
Old 07-19-2013, 04:36 PM
I Looked at the Wikipedia too. I'm running two gallons in my tank now with diesel. No problems. It's oilier than gasoline. appears much like diesel when poured, has a bluish tint to it.
Old 07-19-2013, 04:53 PM
flainn's Avatar
Quote:
You should put that info in the Wikipedia article!
AC System Rebuild from Accident Island Time Cooling, Heating, Ventilation & A/C 2 10-07-2014 09:51 PM
Mechanics Please help! Crank no start after fuel filter replacment! MattyNJ 6.0L Power Stroke Diesel 17 01-16-2014 08:48 AM
ac compressor condensing SLAYER1 Cooling, Heating, Ventilation & A/C 1 06-10-2013 09:32 PM
92 F-150 5.0L parallel flow condenser bnb29 Cooling, Heating, Ventilation & A/C 0 04-17-2006 09:47 AM
replace ac condenser Mike8623 Cooling, Heating, Ventilation & A/C 1 03-20-2006 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
