Tire size(Again...)2001 F150 SuperCrew 4x4 - Ford Truck Enthusiasts Forums
Old 06-12-2003, 09:30 AM
mikentana mikentana is offline
mikentana is starting off with a positive reputation.
I've got a F150 SuperCrew 4x4 and need new tires.
I'm having a hard time (ignorant) finding how large I can go, and what would be ideal.
I've got stock tires, and want to go with something a bit more aggressive, larger, but still good for highway,as I do alot of pavement traveling.
I'm looking for size, as well as manufacturer, and style recommendations.
Thanks for any input.
Mike
Old 06-12-2003, 09:42 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Do you have 16" or 17". 265/75R16 look good on a 16" Wheel, And I like the 17" with 265's as well.
Old 06-12-2003, 09:59 AM
I'm pretty sure I have 16"
It's not the "Off Road" Series...just 4x4...
Thanks!!!!
Old 06-12-2003, 03:54 PM
GrandBlanc GrandBlanc is offline
GrandBlanc is starting off with a positive reputation.
If you have 17" your stock tires are P265/70R17. I have a 01' SuperCrew and it's a 4X4 and I have 17"
Old 06-13-2003, 06:11 AM
Shernius Shernius is offline
Shernius is starting off with a positive reputation.
Iím in the same boat with my 99 supercab! I'm thinking of 255s on the 16" rims. Do you have any thoughts on correcting the speedometer difference? Do you know if itís just a change on the end or the cable on reprogramming something in the computer?
Old 06-13-2003, 07:57 AM
Hookin' 1963's Avatar
Hookin' 1963 Hookin' 1963 is offline
Hookin' 1963 is starting off with a positive reputation.
If you are concerned about fuel economy stay with a narrow tire, If you don't care about economy the bigger the better just don't forget about the balljoint issue on Fords.
Shernius:
To correct the speedometer, it is done through the computer. If you have the Superchip you can do it with that.
Old 06-13-2003, 09:26 AM
Ok. I've got 255/70R16s, and to beat all when I got to my truck last nite I had another flat tire. That's a signal....
I'd like to go at least 265-looking at either BFG All Terrain, Dunlop Rover, or the Toyo Open Country.
Thanks All!
Old 06-14-2003, 04:15 PM
thenetguy's Avatar
thenetguy thenetguy is offline
thenetguy is starting off with a positive reputation.
I've got a new set of TOYO 285 70R/17 which is about as large as you can to without rubbing. Awesome tires and look much better than he stock 265 70R/17.
2003 supercrew tire size and lift questions J ballan 1997 - 2003 F150 2 12-30-2013 01:20 PM
Shock Bolt Size??? yotesniper66 1997 - 2003 F150 0 07-25-2013 10:22 AM
Leveling Kit and Tires muddycreekoutfitters 2009 - 2014 F150 28 09-03-2012 09:51 PM
2001 F150 SuperCrew in 4x4 Issue caper1125 1997 - 2003 F150 5 08-24-2010 09:06 PM
2003 f150 supercrew 4x4 body lift beckham521 1997 - 2003 F150 2 09-16-2006 08:40 PM
Tags
2001, 2004, 4x4, cab, crew, f150, fitment, ford, guide, size, sizes, stock, supercrew, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
