PHP 140 Tune Smoke
You will prob get lots of smoke with any 140 tune on a stock truck. Cant see your sig but I have been told that any tune over 100 is pointless on stock injectors. I don't have any knowledge of PHP tunes. I have have 160/30 sticks with the billet wheel on stock Turbo. It does a pretty good job or clearing.g up the smoke but as I go up in the tunes it smokes more. I am guessing this is a play tune. You wouldn't want to run in the tune all the time.
From what I understand you would be hard pressed to get any more than a 100HP out of stock injectors & the tune just calls for more fuel at the lower RPMs thus the "smoke". BTW I have PHP 120 race tune with a stock turbo & WW, it pushes a little smoke when I jump on it but clears up pretty quickly as the RPMs come up. Like JT says I just use it as a play tune
You may be correct. If you have stock injectors your turbo shouldn't have a problem clearing up the smoke at the top end an turning it into a haze. At least that is how mine is at wot in my 140 aggressive tune. If you are still bellowing black smoke in your high hp tunes you may have a boost leak. If you have bigger aftermarket injectors with a stock turbo you may be running into a problem with not enough air glow for the amount of fuel going into the cylinder.
PEI
24
02-08-2012 07:56 AM
