Rear dif drain plug leaking on the Buzzard
I just had the rear differential serviced on my 74 F-100 (Ford 9 inch rear) and I noticed before that it was leaking at the drain plug. I know you are thinking that there is no drain plug on the Ford 9 inch, well someone added one at the bottom of the differential and it is leaking. After the service it is still leaking, right from the plug itself. Do I need a new plug or is there something else I should be looking for? Can this be welded up or what would be the best solution?
sandroost
03-21-2015 11:18 PM
PassedDown66
05-14-2010 03:34 PM
84 f250 6.9
12-04-2008 11:53 AM
