Rebuild or Replace
Exactly.....If I was a Racer OR a Puller...then I would consider that stuff..I'm, Roofer/Mason..I need RELIABILTY....period...I will get Stage ones.....I will eventually Grenade my E4OD ...and YES spend the 3 to 4 Large to rebuild it ...Thats it ....I have 416K right now...my engine according to Blackstone shows NO wear ..so I will be DEAD .....and my engine will still be running.....It all depend on what you use your truck for........If I want to be an A -hole and do Burnouts ..I have a Dually 460 that can smoke them on demand......I live in a Huge city ..I do not need 4x4..If I did I would ride one of my Bikes.....My Truck is a Mule.......NOT a Race horse.....ie; Solid...... Reliable ...Every Day ......Thats it.... Sorry to all the Members for the Pontifcal Speech.......
I agree on reliability but I also want something with a kick. And your 460 would do dually burnouts? Mine would barely do peg leg SRW burnouts. I guess that's the difference between 3.55s and 4.56s lol
Should I use head studs or just replace my bolts? I think it may have a cracked head or blown head gasket so its all coming apart
If you can find a good parts source to get all the little pieces from, it really isn't a bad swap. There are quite a few guys on here that have done the swap that can give you a complete play-by-play and parts list. The absolute best is to have a diesel ZF5 parts truck to rob parts and pieces from, but if you don't have that, you can still gather the parts separately.
Iv swapped a ZF into my old 460 and it was amazingly straight forward. I had my uncle GIVE me a truck, told me take what I need and give the rest back lol. He doesn't have a diesel parts truck
I could "maybe" scrape up the parts but a parts truck would be a dream. I got this crazy idea thatd work: buy a ZF and get a parts truck with a 460 and manual tranny, even without a running gear at all. All the other parts interchange! The only thing that's different is the bellhousing
That would work for most of the parts, but there are still a few diesel specific parts that would be nice to have for the swap (the manual PCM in particular). The swap can be done without changing the PCM, but the best way is to get the PCM from a manual diesel truck and swap it over as well. There are some minor differences in the way the fueling is controlled that improve the drivability of the truck if you have the manual PCM.
But yeah, good luck. These trucks are getting harder to find, especially if they're 5 speeds.
The 6 speed can be (and has been) done but it takes some modifications to the floor pan because it is taller than the 5 speed. As for the Allison, I don't know. I would imagine that you could work it out to put any transmission behind it that International offered behind the T444E but you might have to make your own transmission cross member and if it were an auto, the PCM interface could be a little tricky.
#28
I was honestly driving around today when it hit me like a speeding bullet!
Allison
Nuff said. Destroked makes an adapter plate to bolt an Allison right up to a 7.3. Only thing is, Ill prolly spend as much on that darn adapter as the tranny itself...
Allisons are "fairly" easy to come by. They've been around since before 01. They had em behind the Chevy 8.1 so theyre at least good til 550 ft lbs
Allison
#29
Im starting to see a problem though... I cant find a stand-alone controller for it. Destroked has one where you can control shift points, shift firmness, and TC lock up but its $1600!!
I browsed around on the interweb and BTS comes up quite a bit. A LOT of guys have awesome success stories with him, including many on here! I wouldn't mind sending my E4OD off to be bulletproofed and warrantied but... $4000+
mr.fordneck
02-20-2011 05:09 PM
CharlesFrankenstein
15
10-13-2009 07:34 PM
