Thinking of airbags, see StableLoad first
Your vehicle factory suspension was designed by the vehicle engineers to carry the payload on the leaf spring suspension. Overloads such as airbags can help a vehicle that is towing or carrying a heavy payload by keeping the vehicle level. Leveling improves braking by shifting more weight onto the front wheels due to a forward shift in the center of gravity and front alignment stays closer to factory specification as again the vehicle is closer to a stock level stance.
The downside to airbag overloads is that they accomplish all this by lifting the weight off the factory-engineered spring suspension. Your vehicle engineers designed the weight to be carried over the progressive 4' rear leaf springs. On any heavy towing or hauling set up, to level the vehicle with airbags means you have to take a majority of the weight off the factory leaf spring suspension and are now carrying that weight on an area roughly equivalent to the size of a two footballs. This is why you can actually experience a considerable increase in unsafe handling such as sway, porpoising (bucking) and body roll even though the vehicle is now closer to level with the airbags engaged.
Torklift StableLoad dramatically improves vehicle handling characteristics by "pre-activating" the stabilizing affect designed into the rear springs by keeping the springs actively under load the way your vehicle factory engineers designed them to operate. The StableLoad accomplishes this and functions equally as well when used with or without airbag overloads. For vehicles that do not yet have airbag overloads, we recommend starting with the StableLoad prior to investing in airbags.
StableLoads are being offered to FTE members as a group buy for a limited time ending 8/5/13.
See http:www.torklift.com/fte for more information.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-05-2018 03:07 PM
Torklift Sheryl
02-21-2017 06:51 PM
Torklift Sheryl
02-02-2017 04:44 PM
Torklift Sheryl
06-02-2016 07:48 PM
