2004 Explorer Eddie Bauer - Ford Truck Enthusiasts Forums
Old 07-16-2013, 01:49 PM
brucecassida brucecassida is offline
brucecassida is starting off with a positive reputation.
I have a 2004 Explorer with 167,000 miles that has begun to display erractic messages such as, check charging system, low tire pressure, AvTrac off and about everything there is. Reset and everything looks good then messages start again. I am thinking computer module but would like some pro opinions from anyone on fixes. Thanks.
Old 07-16-2013, 04:39 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Hey Bruce, welcome to FTE bud!, I see you're having trouble with your truck, I'll redirect your thread to a better Chapter for you to get the info you're looking for. You'll find it in this Chapter: Explorer, Sport Trac, Mountaineer & Aviator - Ford Truck Enthusiasts Forums
Personally I would check the connections between the display, the computer and the main wiring harness, otherwise the ECM could be on its way out.
Old 07-16-2013, 05:29 PM
2004 Ford Explorer Eddie Bauer
Thanks for the ideas and getting me in the right direction. Hopefully this will help narrow the problem or fix it.
Old 07-17-2013, 06:34 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Also, consider changing out the battery if it's more than a few years old. It seems a lot of modern cars start doing some strange electrical things when the batteries age. Even when the battery tests fine and cranks the engine over fine, it might be just weak enough to cause electrical issues. And with your Explorer being a 2004 it could easily be due for battery #3 (assuming 4-5 years per battery).
For example, my wife had a 2002 Lincoln LS. For the first drive of the day she'd back down the driveway, stop in the street, and shift to drive. As soon as she did so, the car would stall. It always started back up with no problems and ran fine. I tried a few different things, nothing made a difference. Then, based on a post in the respective forum similar to what I typed above, I changed the battery which, per the date stamp, had only been in the car 3 years. The stalling never occurred again.
-Rod
2004 explorer windows quit working - jabro Explorer, Sport Trac, Mountaineer & Aviator 9 01-19-2016 03:55 AM
SUSPENSION MarauderV8 2007 - 2014 Expedition & Navigator 0 11-09-2014 11:46 AM
Change Oil Soon, Message motown 2011 & Newer Explorer 10 06-21-2012 05:48 PM
Door Ajar w/ Rear Window Defroster Baywatch13 Explorer, Sport Trac, Mountaineer & Aviator 1 05-07-2012 07:07 AM
Rear Differential match????? leeallen Explorer, Sport Trac, Mountaineer & Aviator 0 03-22-2012 06:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
