351 W - what headers should I get
I second Dave's statement, but do so from a very limited experience point of view. I've been around two of of these trucks with headers - Ray's 302 and Bruno's 351W. I haven't looked at how Ray's fit, but Bruno's make access to the plugs almost impossible. And there is absolutely no way to do a compression or leak-down test. It may be that other brands fit better, but that experience soured me on headers.
If you do get some, let me know how they fit. I am a little skeptical on getting them because I can't see how they are going to fit past the clutch fork sticking out my tranny. I would imagine that it would make doing simple maintenance on your truck very difficult though, as a few on here have stated.
I don't know if there is any difference in the Firewalls between Bullnose and Bricknose trucks. but this is the current setup on my 88 Bronco. I'm running Headman Elite Full-length headers to a custom y-pipe. It's a full 3in stainless system. I have a single Summit electric cutout next to the t-case, followed by a Flowmaster 40 series...exiting out the the stock location. 358W, C6 trans.
There's not much room to run true duals on a 4wd. The T-case, and in the F-series case...the front tank also gets in the way. You could run both side-by-side on the passenger side. But the more bends you have to make, the less efficient it will be...Efficiency equals power.
My Headers...Headman Elites
Right side when I was putting it together.
...And the Left side.
Right side close up.
Collector location.
Y-pipe, Cut-out, and Muffler locations.
Exit Location.
Hopefully this helps...It sounds great for having a FloMonster on it. Some install notes...Can't install from above, Have to work them in from underneath. You can install the left with the front driveshaft in. But I HIGHLY recommend pulling it. I had to cut a wrench down real short and grind down the open ends thinner...Not much room by the Heater box to work with. and it's real close to the firewall. I can post a sound vid if your interested.
Collector location.
Exit Location.
On the subject of headers, I used Hooker long tubes. Fit well, work well, but there is an interference issue with the shifter lever on a C6 auto.
gears will definitely help get you into the powerband and stay there, albeit it can be expensive, but if you search on craigslist you can sometimes find direct swap axles with 4.10s (at least around here) and you can sell your old axles to recoup some of the cost.
