Question for the 226 flathead six experts - Page 2 - Ford Truck Enthusiasts Forums
Old 07-20-2013, 05:46 PM
pineconeford's Avatar
pineconeford pineconeford is offline
pineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to behold
Marauder, congratulations!
And it sounds like you beat me by an hour or so to get yours to start first.
Don't they sound great?!!
I'll start another thread and see if I can post a video.
Tom
Old 07-20-2013, 06:05 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
congrats to you too! They do have a distinct sound! Let's see some video of that jewel you have.
Old 07-29-2013, 10:46 PM
brain75's Avatar
brain75 brain75 is offline
brain75 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Marauder2004 View Post
A question for brian75: You mentioned oiler pip then timing pip- can you elaborate a bit on this? I'm just not sure which area you are referring to.
Sorry for bringing this back when it had settled down to 3rd page, but I wanted to answer the question and most importantly give future searchers a "rough 'in the field' timing guide"
So looking at the photo (far left, center - highlighted by sunlight) you can see the damper's timing mark is a circle - I called this a timing pip - not the "mark" I am used to on everything else Ford (thin but very definite line)... see in the pic (bottom right) how the rotor points almost perfectly at the red mark on the dizzy body. I took red sharpie and marked my dizzy on the casting seam, there's a very definite casting seam there. Straight behind that casting seam is the oiler pip I mentioned - little flip top covered spot for lubing the dizzy.
In the field with no timing light you can at least start there, and I about guarantee that is "close enough" to get it to at least stumble to life - tune it by ear, lock it down then drive it to the shop where you can use the timing light proper.
Old 01-02-2014, 07:16 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Quote:
Originally Posted by 38 coupe View Post
I have seen several engines that would not start from the starter after sitting for years. The solution was to get brakes to work and then pull start.
Yea my dad was a mechanic by trade and was always tinkering on old Flatheads when I was a kid. We would go out and pull them after dark on backroads. I always got the car being pulled and they always started although sometimes we pulled them for several miles. Those are some of my fondest memories as a child, and no I never run into the back of the pull car.
Old 01-03-2014, 09:47 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Another method I have used to time both 8BAs and H / M series sixes:
1. Line up the crank pulley / vibration damper bump with the timing cover pointer. You may advance it a few degrees based on your altitude, type of fuel available, etc.
2. Pull the distributor cap and rotor.
3. Loosen the distributor clamp bolt.
4. Retard the timing as far as it will go on the distributor without damaging the vacuum line. Your points should be closed. If your points are open you have a problem.
5. Turn on your ignition switch.
6. Have your wrench in your hand ready to tighten the distributor clamp bolt.
7. Advance the distributor slowly until you see a spark at the points. This will happen when the points first open. Stop moving the distributor. If you aren't sure if you moved the distributor, back it up and do it again. Repeat as necessary to ensure you know when the points open.
8. Tighten the distributor clamp bolt without moving the distributor.
9. Reinstall your rotor and cap.
10. Smile. Your engine is now timed properly and you don't need a timing light.
Old 01-05-2014, 04:17 AM
51ford fan's Avatar
I always do the same, except on #7 I put a piece of notebook paper between the contacts and close the points. Then bring the Distributor back till I can just pull the paper freely. My Auto Shop teacher showed me that in 1967.....
Old 01-05-2014, 12:31 PM
DougofMontana's Avatar
DougofMontana DougofMontana is offline
DougofMontana is starting off with a positive reputation.
Greetings. I too have a '49 F1 with the 226 that I bought in August. The weekend I brought it home I hooked up a 12V battery and rolled the engine over just to confirm that it would. Just this weekend, after installing new points, condenser, rotor and a 12V coil I added a little gas to the carb and cranked her over. I got fire, and it "tried" to run. After about 20 seconds of cranking I quit and fiddled with the carb a bit before trying again. However the starter would not turn over. I have plenty of juice, but can't get it to crank Any ideas? I loved the audio by the way!
Old 01-05-2014, 06:19 PM
51ford fan's Avatar
Quote:
I would take jumper cables hook them up and ground the negative and touch the positive directly on the stud on the starter the positive connects to. If if won't turn that way it's most likely the starter, you could try rocking the truck back and fourth to make sure the engine is still free. When I first tried to fire my 226 It kept doing that and I found the flywheel bolts had come loose and the ring gear was dragging in there. Personally I like to always use Starting Fluid it always seems to work better for me.
Old 01-06-2014, 09:21 PM
Just got back from a road trip and before I put my battery back in my driver I tried the F1 again. Still no movement, but I noticed the dipstick moves slightly when I put power to the starter. I have the truck up on stands, no box, no fenders, no doors, etc., etc., so I have put a ratchet on the dampener bolt and the engine turns freely. I'm thinking I will pull the starter, open things up enough to see the ring gear and such.
Old 01-06-2014, 10:13 PM
51ford fan's Avatar
Old 01-06-2014, 10:39 PM
I have a heated garage... stays a balmy 62 degrees
Old 01-07-2014, 08:18 AM
I had a similar experience with my F4 when I was trying to get it to start- at one point thes starter would just not respond. No click, no turn, almost as if there was no battery connected. I removed it, connected power to it on my shop floor and it came to life and slung across the floor! I put it back on and it has worked fine since. I don't know what the issue was, but I would guess there was a connection issue on either the hot or ground that I probably could have discovered without removing it.
First Run 8BA - Have some questions dlb.motorman 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-19-2015 07:32 PM
Where do I plug the scanner in? Thipdar 1967 - 1972 F-100 & Larger F-Series Trucks 19 02-15-2014 03:51 PM
1968 F100 has 1974 302 v8 - Won't Start! Help!! rahnpreston 1967 - 1972 F-100 & Larger F-Series Trucks 31 10-14-2013 02:04 PM
76 300 Trouble getting it started jlab1977 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-20-2011 12:57 AM
'83 F100 Inline Six Carburetor Woes Greenmillwork 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-05-2009 03:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
