Hard hesitation
07-16-2013, 06:23 AM
on
Hard hesitation
My truck runs fine when driving it normally but if I really put my foot in the pedal and get to 2800 rpm I get a real hard jerking like the engine isnt running right almost like its missing I originally thought it was the engine not getting enough fuel because my efuel was set at 62 psi so I bumped it up to 70 and I'm having the same problem can anyone shed some light on the issue? Any help would be greatly appreciated.
07-16-2013, 06:34 AM
Do you have a way to see ICP ?
07-16-2013, 10:52 AM
on
Not until tomarrow unfortunately
07-16-2013, 02:08 PM
on
It won't accelerate past 3k at all it's shaking and jerking around to much it falls right on its face
07-16-2013, 02:21 PM
07-16-2013, 04:02 PM
on
Nope nothing it drives fine any other time with no issues just when it gets rev'ed up I get this issue
07-16-2013, 07:45 PM
It sounds like the oil can't keep up but it should set a CEL
07-16-2013, 07:46 PM
07-17-2013, 10:15 AM
on
No chip just efuel,intake and a high pressure oil crossover.
07-17-2013, 01:03 PM
Any way to check fuel pressure under load? With e-fuel if the filters plug you can get good pressure at idle but not under engine demand.
07-17-2013, 01:36 PM
on
Can I do that with a scanner? I don't have a way to look at the gauge while I'm driving the truck.
07-17-2013, 02:40 PM
Quote:
Originally Posted by
96ford250
Nope, but you could check your fuel filters or just replace them.
07-17-2013, 03:32 PM
on
They are pretty new but it could be the problem only had the whole truck running for a month or 2
07-17-2013, 10:33 PM
You'll have to make up a gauge with a 4-5' hose so it'll reach to the cab so you can see it
F-ing 100
38
09-13-2014 07:17 PM
agamble
08-08-2012 10:13 PM
big79bronco
01-27-2011 01:57 PM
guthrie&co
02-08-2009 12:54 PM
strokin'_tatsch
39
03-15-2008 10:01 AM
