Y block Identification - Ford Truck Enthusiasts Forums
Old 07-15-2013, 09:32 PM
craigerspaz craigerspaz is offline
craigerspaz is starting off with a positive reputation.
Where on the engine can I find the Y block engine size?
Old 07-16-2013, 04:32 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
You can start with the block number. It will be just above the oil filter or on the passenger side, near the generator, or near the distributor.
Old 07-16-2013, 04:53 PM
thanks a bunch
Old 07-16-2013, 06:28 PM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
This link might help in deciphering what you have.
TECHNICAL
Old 07-16-2013, 09:37 PM
Thank you very much for the info
292 Y block for Sale in NH jack71 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 05-23-2015 01:35 PM
Y block filthy6 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-17-2014 08:07 PM
New Y-Block Book Y-Blockhead Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 04-14-2014 09:50 AM
1954 239 OHV ENGINE SPECS.... fastphil 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 10-01-2011 02:22 PM
272 Engine Yellow dylan1952 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 08-19-2010 09:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
