I think I'll post this in the Super Duty forum too. As they say, a picture tells a thousand words. Here's a couple pictures of the '08+ Torqshift's internal transmission filter. Ours only has a screen for a filter and the new one has a nice pleated filter PLUS a fine SS screen with a bypass valve, incase the pleated filter plugs. The upgrade will allow 100% oil filtration versus about 10% of the oil that the front filter sees. So if you have both I guess you get 110% filtration!
You need both the filter and the '08+ pan for the upgrade, gasket is re-usable. Tousley has both for about $93 w/o shipping...
I can see that Newer filter is Days Better then what we have
Price isn't bad either for this Mod
By chance do you know what the recommended service interval is??For this New Filter
Still 30K ??OR ??
You know, I don't know what the '08+ interval is, but I thought it was higher than our 30k, but maybe it was oil every 30k and filter every 60k? In another thread here somewhere, Mark Kovalsky weighed in with an interesting tidbit: and that was he'd never seen an internal transmission filter clog, even in ones run up to 300k miles! (not a direct quote mind you). I'm taking a different path and once the new filter is in there I'm going to 20k dump and fills only. I'm not going to bother trying to find someone with a hot flush machine, etc.
I have a couple of external filters I bought before deciding to go this route. If the housing comes off with no problem I'll use those too and when they're gone leave the external housing empty...
That's true, but I was speaking about the older filters. I do not know how long this newer filter will last. I suspect A LOT less than 300k miles because it is a very fine filter. The old filters were mainly boulder catchers.
Most of the deep sump pans come with a filter (intake) extension, you might check with B&M on if they have an '08+ one, or if the one they should have supplied with your original pan is the same. But then get the new filter -- it is really a: "why not?" question...
very interesting! thanks for the info, diesel dan. i've been thinking a lot bout it myself, especially since i had some trouble with my external filter housing. damn thing.
i guess u can update ur signature now to show u gots the 08 tranny pan! oh, and does it still take 9 quarts when u drop the pan or does it take more?
