recently purchused a 1990 f150 4x4..
Old 07-15-2013, 09:47 AM
haukin99sdp's Avatar
haukin99sdp
haukin99sdp is offline
it is a 5spd with the 300i6. man i love these old trucks but anyhow...
the guy said the speedo didnt wrk so i crawled under the truck to find the cable jus dangling there. started looking around on the tranny and tcase for the vss to hook it back in and, well....... theres not one.
i think i kno where it should be but its not there nor any indication there was ever one... so... im kinda confused on this and any advice help, and/or info is much appreciated.
shouldnt it be at the rear of the tcase??
Old 07-15-2013, 09:54 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
It probably has a later transmission/TC, they moved the VSS to the differential in 92 ... This was done when the speedometers went all electronic...
Old 07-15-2013, 10:15 AM
Conanski's Avatar
Conanski
Conanski is offline
Yes.. so it would appear the truck doesn't have the original T-case in it.
Old 07-15-2013, 07:12 PM
haukin99sdp
thanks guys..
so.. i geuss i should find out what tcase i have then? would there be any way to mod it to make it wrk or will i have to swap out the case? could i maybe get away with jus swaping the tail section of the case?
Old 07-16-2013, 07:46 AM
haukin99sdp
any info and\or help to get my speedo back to wrking will much appreciated.
Old 07-16-2013, 09:20 AM
dixie460's Avatar
dixie460
dixie460 is offline
You could keep your existing case and swap tailcones, but you'll also have to tear the case down (easy job) and put the speedo drive gear on the output shaft to get it to work.
Only other choice is to replace the entire transfer case with one that's set up for the mechanical speedo.
Old 07-16-2013, 10:23 AM
haukin99sdp
so.. is there any diffrence in the tcase's then? gearing or anything tht would make one a bit better than the other?
Old 07-16-2013, 10:36 AM
jas88's Avatar
jas88
jas88 is offline
Any BW1356 will work as long as it has the tailcone that will accept the speedo gear.
Incenter12
03-23-2012 10:13 PM
glovemeister
09-14-2011 09:29 PM
ManicMike
02-27-2010 05:18 PM
86fu50
12-16-2006 06:58 PM
tukes48
11-28-2004 05:31 PM
Quick Reply: recently purchused a 1990 f150 4x4..
