1962 F100 4x4 front to rear ratio mismatch questions - Ford Truck Enthusiasts Forums
Old 07-15-2013, 08:22 AM
old broke prospector old broke prospector is offline
old broke prospector is gaining momentum as a positive member of FTE.old broke prospector is gaining momentum as a positive member of FTE.
If I put lower ratio gears (higher speed) in the rear differential on my 4x4 it seems the rear end will be pushing the truck when in 4x4, but when the rear starts slipping, the front will take over and pull. This does not present a problem in my feeble mind so I am seeking the forum's experience.
Will there be any damage to the truck in 4x4 if I go with a higher speed rear end?
Old 07-15-2013, 12:18 PM
TA455HO's Avatar
TA455HO TA455HO is online now
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
It sounds risky to me, but then I've not known anyone to do such.
The normal ratio is lower in the front than in the rear so the front is always slightly pulling when in 4WD. For example, my 1966 F250 4x4 has 4.56 gears in the rear and 4.55 in the front. This causes the front to pull slightly (.01 difference) and the steering will work as expected.
With your idea the rear is always pushing, possibly causing it to push you through corners and overpower the steering capabilities. And this is on loose terrain such as a gravel road. On blacktop or even a sticky patch of dirt it might be enough to overload the front and break something.
For it to work smoothly with significantly different gears it seems like the transfer case would have to be designed to take up some of the slack, sort of like a differential does when cornering, but instead of side to side it would be front to back. But as designed they don't provide for that compensation. Otherwise you are counting on tires slipping at the right times when it is required and then not slip when you don't want it to, like when steering.
I don't think you'd have that control over it. If the tires don't slip then something would have to break. Most likely in my mind would be the transfer case or driveshaft u-joints would be the first to go.
But, it's your truck so you can certainly experiment all you want.
Old 07-15-2013, 12:26 PM
Quote:
For it to work smoothly with .....
Good clean logic, thanks.
Old 07-15-2013, 08:51 PM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
I wish the guy who rebuilt my third member would have explained things as well as that.
He put it in simple terms for me and said it would be bad.
My simple mind agreed and I stayed with the original ratio on the rear.
I think I made the right call..
Old 07-16-2013, 12:51 AM
F&M's Avatar
F&M F&M is offline
F&M is starting off with a positive reputation.
I've heard the push-pull thing before,but that made a loud clink when I read it.Kudos for that explaination..thanks
Old 07-16-2013, 04:08 AM
ihateminimumwage's Avatar
ihateminimumwage ihateminimumwage is offline
ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.
You'll be okay if you're only doing a difference in approximately .01-.02 ratio (4.09, 4.10, 4.11 for example), anything over that will grenade your transfer case or driveline the minute the front and rear both grip anything at the same time.
Old 07-16-2013, 04:16 AM
KsCop's Avatar
I had 3.89 in the rear and we talked about 4.11
That would have been bad...
My trucks gear ratio in the rear end BIC 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-10-2009 09:56 PM
1978 ford f150 gear ratios themudhog86 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-21-2008 07:09 PM
Rear End Gear ratio blloyd 1987 - 1996 F150 & Larger F-Series Trucks 36 11-29-2007 12:05 PM
Question about rear ends. dnachristen Bronco II 4 01-06-2006 04:04 PM
Specs grumpyjjo Bronco II 12 08-21-2004 11:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
