My new Powerstop brakes before and after
#32
Thank you, Brent.
Saying that you dont need "better than OEM breaks" equals not
that all upgrades on breaks are nonsens.
Bottom Line:
There are custom kits/sets out there and some mods (brake lines /hydroboost)
can be done wich will gives you a huge improvement in stopping power
but you dont need them.
Ok. But they exist. Right?
Great.......and now where this is said loud and clear......Lets get some beer
Bottom Line:
#35
I installed mine in December. We're about to hit May and I've already burnt through my pads with daily driving.
I installed Powerstop: Calipers, Rotors and Pads.
I'm not sure about radmacks calipers but mine were the same red but did have the OEM Ford stamp on the caliper bodies, it looks like powerstop just puts 'beefier' components in them.
Here is what I installed:
#36
on
Here is what I installed: Amazon.com: Power Stop (KC1905) 1-Click Performance Brake Kit with Calipers: Automotive
#37
Id be willing to bet that they are just remanufactured factory calipers that are painted.
But hey... they do look good and if you think you need new calipers then the price seems pretty good.
#38
#39
on
I was curious too but after reviewing both the oem specs and powerstop specs the only difference that I could find was the claim on powerstops behalf of "Premium boots/seals and high-temp silicone lubricant on caliper pins".
#40
#41
on
To improve braking performance... stainless steel brake lines and flush the brake fluid, is about it, without increasing the sweep area and using four piston calipers. HD metalic pads will help heat fade going down a steep grade and cryo rotors will out perform standard rotors life.
#42
#43
#45
