T98a Input Bearing Retainer Question
Old 07-14-2013, 09:37 PM
NateTheGreat's Avatar
NateTheGreat
NateTheGreat is offline
I'm rebuilding my T98a and was doing the final buttoning up when the input bearing retainer cracked all to pieces.
Now I can't find a new one for the T98 anywhere.
Would the input bearing retainer for a T18 be the same part? It appears the case is the same but not sure if the bearing retainer is a direct swap.
Thanks in advance!
Old 07-14-2013, 11:37 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
It is possible an early T18 would work, they say they used the same case and top cover:
The Borg-Warner T18 & T19 Transmissions - Novak Conversions
Parts:
Parts for the Borg Warner T98 Transmission
Old 07-15-2013, 04:32 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Now I can't find a new one for the T98 anywhere. Would the input bearing retainer for a T18 be the same part?
B6C-7050-A .. Input Shaft Bearing Retainer / 4 1/8" O/A length / R.H. spiral oil grooves / 5.124" flange O.D. / 3 49/64" flange I.D. / Obsolete
T-98: 1956/64 all trucks / T-18: 1965/67 F100/250 2WD & F350 240/300 I-6 & 352 / 1968/72 F100/250 2WD & F350 240/300 I-6 & 360/390 / T-19: 1968/72 F500/600 I-6 & V8 (gas).
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Old 07-15-2013, 09:10 AM
NateTheGreat
Thanks a bunch, guys. I will call Green. (I used to live in LA but moved to Abq, NM about a year ago).
poky1234
06-25-2018 05:05 AM
Catspaw
09-12-2017 07:44 PM
BarbToothaker
09-28-2015 10:51 AM
ige1963
01-03-2015 02:41 AM
matt2491
06-22-2008 05:29 PM
Quick Reply: T98a Input Bearing Retainer Question
