T98a Input Bearing Retainer Question - Ford Truck Enthusiasts Forums
Old 07-14-2013, 10:37 PM
NateTheGreat NateTheGreat is offline
NateTheGreat is starting off with a positive reputation.
I'm rebuilding my T98a and was doing the final buttoning up when the input bearing retainer cracked all to pieces.
Now I can't find a new one for the T98 anywhere.
Would the input bearing retainer for a T18 be the same part? It appears the case is the same but not sure if the bearing retainer is a direct swap.
Thanks in advance!
Old 07-15-2013, 12:37 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
It is possible an early T18 would work, they say they used the same case and top cover:
The Borg-Warner T18 & T19 Transmissions - Novak Conversions
Parts:
Parts for the Borg Warner T98 Transmission
Old 07-15-2013, 05:32 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Now I can't find a new one for the T98 anywhere. Would the input bearing retainer for a T18 be the same part?
B6C-7050-A .. Input Shaft Bearing Retainer / 4 1/8" O/A length / R.H. spiral oil grooves / 5.124" flange O.D. / 3 49/64" flange I.D. / Obsolete
T-98: 1956/64 all trucks / T-18: 1965/67 F100/250 2WD & F350 240/300 I-6 & 352 / 1968/72 F100/250 2WD & F350 240/300 I-6 & 360/390 / T-19: 1968/72 F500/600 I-6 & V8 (gas).
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Old 07-15-2013, 10:10 AM
Thanks a bunch, guys. I will call Green. (I used to live in LA but moved to Abq, NM about a year ago).
WTB: T98 rear bearing retainer / mount ghalperin WTB - Parts & other 2 12-22-2016 11:47 PM
T98 Input Shaft oil seal kj6opf 1957 - 1960 F100 & Larger F-Series Trucks 2 10-08-2016 12:12 PM
Dana Spicer 44 rear axle retainer john jamieson 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-04-2016 08:13 PM
Looking for availability NOS 31-spline Axle Bearings p/n D0TZ-1225-A ultraranger 1967 - 1972 F-100 & Larger F-Series Trucks 27 01-23-2015 08:30 PM
Need a T98 4 speed bearing retainer fiftysixfordf250 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-07-2008 02:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
