cleaning crankcase of 4.6 - Ford Truck Enthusiasts Forums
Old 07-14-2013, 08:04 PM
Dewdzilla Dewdzilla is offline
Dewdzilla is starting off with a positive reputation.
Hi guys,
this will be my first post on the forum. here is my question i have a 98 f150 2wd 4.6 the truck began showing signs that it needed a head gasket about 2k miles ago, my coolant reservoir smells like gas and the coolant is a rusty brown color the truck smokes slightly and the oil cap has chocolate moose like substance from the oil mixing with water. I dont care to keep the truck to much longer however i need it to last me to the end of year. I purchased some k-seal and new oil/coolant etc but after thinking about it all of that chocolate moose up in the valve covers will still be in my motor after i perform the oil change and coolant flush. How should i go about attempting to clean the motor out ? seafoam scares me because i do not know if my rings are already damaged from driving while needing the headgasket, Or should i just keep doing oil changes until it looks clean? any help would be much appreciated.
Old 07-14-2013, 10:48 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Welcome to FTE.
End of the year might be a stretch.
Is it missing or running poorly? Water on a plug?
Old 07-15-2013, 12:05 AM
wasnt missfiring at first, however it just started running alittle rough. was throwin p0302 but i found a loose plug wire and the codes gone. still runs rough tho, i think a plug might be fouled. i dont have the money to fix the motor properly im just trying to get alittle life outa her.
Old 07-15-2013, 04:52 PM
so should i try ATF, diesel fuel or seafoam????
Oil filter full of coolant! seemoremud Modular V10 (6.8l) 17 01-25-2017 01:19 PM
F-150 5.4L blown head gasket? matt1260 1997 - 2003 F150 6 09-28-2016 02:33 PM
2006 Ranger need guidance.... Thoth88 Ranger & B-Series 12 01-15-2014 03:18 PM
chocolate milk in the radiator jccapri 1999 - 2003 7.3L Power Stroke Diesel 4 12-29-2012 02:45 PM
Here goes another head gasket thread...mine just went bye bye armydude Excursion - King of SUVs 34 06-13-2012 07:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
