66 F100- 1968 390 HELP!
Old 07-10-2013, 07:55 AM
reddnekk's Avatar
reddnekk
reddnekk is offline
My 68 390 is still using oil. A qt. every 100-120 mi. Bad re-build from the start. 1. Stretched head bolts-replaced. 2. Valve job complete- stopped the smoking. Everything is new. No smoke, no oil underneath or on the floor. Still uses oil. NOW WHAT?
Old 07-10-2013, 08:01 AM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
If it is using that much oil you are just missing it somewhere. If it is not marking it's territory then it almost has to be burning it. I guess it could be going into the water but I would think that easy to find. It may not be burning enough at idle to see. Have somebody follow you while driving & just drive normal at first then a time or 2 nail it like you are going to pass someone. Whoever is following will let you know. What does your tailgate look like? Little oil spots?
Old 07-12-2013, 08:56 AM
robertbruce's Avatar
robertbruce
robertbruce is offline
is it using much less oil?
is it possible it still "running in?"
Old 07-12-2013, 10:21 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Torque-to-yield headbolts? That's a new one on me for this era of engines.
Blip the throttle. Got smoke?
2x with above... sooty exhaust with small flecks?
Is there a light haze behind ya while on the road?
PCV in working order? Is the splash shield under valve cover intact?
Old 07-12-2013, 10:38 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
1qt every 120miles is a lot , it's going somewhere . pull plugs how do they look ? I am guessing wet .
Old 07-16-2013, 08:15 AM
reddnekk's Avatar
reddnekk
reddnekk is offline
I will mention those things. Thinking now that the rings haven't seated. Maybe?
Old 07-16-2013, 08:32 AM
reddnekk's Avatar
reddnekk
reddnekk is offline
Thinking now that the rings have not seated. Maybe? Less than 3,000 mi. on this motor.
Old 07-16-2013, 08:44 AM
MIKES 68 F100
Rings should have seated by now , something is not right !
Old 07-16-2013, 01:50 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Out of curiousity, did your engine builder bore it out and then match pistons and rings to that spec? Not trying to insult anyone I just think outside the box.
Old 07-16-2013, 01:55 PM
MIKES 68 F100
jefffafa ,, that would do it
Old 07-16-2013, 01:56 PM
MIKES 68 F100
have you done a compression check ? if so what was the numbers?
rustywheel68
24
12-31-2010 04:04 PM
dannybatten
04-08-2009 04:33 AM
bob arrington
11-21-2005 07:29 PM
cjben
06-22-2001 09:29 PM
jowilker
10-27-1999 06:51 AM
Quick Reply: 66 F100- 1968 390 HELP!
