Oil filter relocation kit - Ford Truck Enthusiasts Forums
Old 07-13-2013, 11:16 PM
Blue 55's Avatar
Blue 55 Blue 55 is offline
Blue 55 is starting off with a positive reputation.
Due to the exhaust being too close for comfort after installing a set of rams horns, I put an Oil filter relocation kit on my 239 today. So far-so good. The claims are that this kit will help reduce oil temperature as well. Anyone else ever use one? Also took the generator off today and installed an alternator using the bracket from Mummert. Took a little longer timing cover bolt for the tensioner but other than that it was a smooth transition.
Old 07-14-2013, 12:40 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
I use a remote oil filter adapter. One problem is extra connection points which may result in leaks. Another more difficult problem was a relaxed seal at the block. I've worked on it multiple times, and the suggestion here is go back to the oil filter on the block.
Old 08-03-2013, 10:59 PM
Blue 55's Avatar
I do have one leak on the inlet hose to the filter adaptor but thinking the crimping tool will fix it. I also put a mechanical oil pressure gauge in place of the original sensor. Can't get the oil to flow up the tube though. I have checked the fitting on the block, the fitting on the gauge and the tube itself. Have tried the plastic tube that came with the gauge and also tried a copper tube kit. with the tube installed up to the gauge I can blow back into the block but when I crank the truck no oil comes up the tube. When I disconnect the tube from the fitting on the block and crank the truck plenty of oil squirts out of it, so I know there is pressure coming out. I can't figure it out....
Old 08-04-2013, 09:47 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
The air in the tube to pressure gauge is not a problem. Gauge should read just fine. If not, gauge is defective.
Old 08-04-2013, 09:52 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
This is just a wild guess but it sounds like the air needs to be bled off might help. Try letting the engine run and crack the fitting at the gauge lose and see if it will push the air out, similar to bleeding a brake line..
While I was typing another post was added saying the air isn't a problem, so disregard my suggestion.
Old 08-04-2013, 11:20 AM
schoo's Avatar
schoo schoo is online now
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
Quote:
So how do you like the horns?
Are they used or new made by?
Pix would be nice
How much $
Boy a lot of????
Old 08-04-2013, 05:27 PM
Blue 55's Avatar
I disconnected the line from the back of the gauge and after about 15 minutes of idling I finally got a drop of oil. then it started coming out at a rate of about one drop per minute....
after I fix the leak on the inlet hose to the filter I'll drive it around some and see if the oil starts to come out faster from the tube.
I got the horns from Mummert's site. $350. I feel it was a great investment. Made a huge difference. I would do it again - without a doubt!
I have some before and after pics in my garage/album.
Old 08-05-2013, 05:39 PM
Matt1966's Avatar
Matt1966 Matt1966 is online now
Matt1966 is starting off with a positive reputation.
The Ramhorns looks great! I would like to install this on my truck to but i live in Sweden and have to make a good plan for the conversion. I love my truck but not the sound from the single exhaust. Is it possible without relocating the oil filter or dipstick tube? Really appreciate suggestions. If you dont understand my school english, just let me know and I will try to explain better. The truck is a F100-56 with Fordomatic. Thanks!
Mats
Old 08-06-2013, 04:35 PM
charliemccraney charliemccraney is online now
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
I can't really speak for the 50s F100s but when I had original Rams Horns, there were no issues with the oil filter.
Maybe some blocks have a slightly different position for the oil filter?? Maybe it's only older blocks??
The dipstick will need to be revised as well. I think the tubes for use with the rams horns are available somewhere.
I use the car dipstick location with a shortened car dipstick. With this arrangement, there is about 1/4" of oil on the dipstick when it is full.
Old 08-06-2013, 05:05 PM
Matt1966's Avatar
Thanks!
I found the Rams Horns here
FORD Y
but the custom dipstick tube they use to sell is not available. I also thought I
had to relocate the oil filter or use an adapter for spin on oil filter to get some more space for manifold clearance but I dont know for sure.
Appreciate all help I can get to plan my conversion. Thanks a lot!
Mats
Old 08-06-2013, 05:37 PM
Blue 55's Avatar
I didn't really "have" to relocate the oil filter, its just that I was uncomfortable with it only being 1.5 inches away from the exhaust, and the way the new dual exhaust was ran it made it almost impossible to get the filter off for oil changes. It might have been ok to leave it like it was, but I feel better now. I did have a spin-on kit, which is what the relocator kit screwed on to. As far as the dipstick, it was only a slight bend towards the cab and the manifold fit just fine. I will probably pick up one from Mummert anyway if he gets more in at a later date though.
Old 08-06-2013, 06:13 PM
Matt1966's Avatar
Thanks! I have to think about it for awhile and make a decision. Is it possible with a shorter spin on oil filter to get some more clearance to the manifold? Are there to different locations for the dipstick tube on y-blocks?
I think some pictures shows the dipstick tube in the front of the manifold and some in the middle of the manifold? Thanks a lot everybody ! ! !
Mats
Old 08-06-2013, 06:42 PM
I'd just get the manifolds installed and then see if you need to do anything special. I had no problems with a normal sized filter.
I have headers now and that is much tighter, but still plenty of room.
For the dipstick, car's used the front locations and trucks used the middle location.
Old 08-06-2013, 06:51 PM
Matt1966's Avatar
Thanks again! Sounds like a great suggestion. I will order the manifolds and
then see what happends with the oil filter and dipstick tube.
Mats
Old 08-15-2013, 04:49 PM
Blue 55's Avatar
Got the oil pressure situation corrected. The relocation kit was too far away from the motor and took too much for the oil pump to push the oil that far and still have enough pressure to push the oil up to the gauge. The first hoses I used were almost two feet long because I wanted to get the filter to a certain spot. Once the hoses were shortened to about a foot long the gauge read 60 psi. leak is fixed, pressure in good, now I feel better! Got the compressor for the AC today and am going to start finding a way to mount that next.
5.8 oil filter relocation Ddaybc 1987 - 1996 F150 & Larger F-Series Trucks 5 10-23-2016 12:17 AM
Oil filter relocation kit? 75Player 2004 - 2008 F150 5 02-06-2015 01:30 PM
1997 F53 Motorhome Chassis 7.5L 460 97Ford53 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 12-21-2014 06:33 PM
oil filter relocation in 7.3 walterkurtz 1999 - 2003 7.3L Power Stroke Diesel 24 10-05-2012 08:36 AM
OIL FILTER RELOCATION/COOLER AJHEATING Ford Inline Six, 200, 250, 4.9L / 300 1 08-22-2011 08:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
