1999 F250LD 5.4L Auto 4X4; No start, low voltage at Inertia switch - Ford Truck Enthusiasts Forums
Old 07-13-2013, 06:59 PM
labadida1 labadida1 is offline
labadida1 is starting off with a positive reputation.
Hello All, I am new to the forum, I live in Morrow, Ohio. I bought this truck and have been working on this problem for two full days. It has been sitting for over a year and was told it needed spark plugs and a battery. I replaced both items and it turned over, would start with starting fluid but only briefly. I disconnected the fuel line on the tank side of the filter and had my son turn the key on several times, no fuel. I reconnected the line and tested voltage at the tank (Pink and blue (+) and black (-). No voltage. I went to the fuse box under the hood and have good 15A fuse with 12.5V there with the key on. The relay also makes 3 audible clicks when I turn the key on. I tested the inertia switch green/yellow wire; 6.8V grounded to the truck or to the small brown wire. I looked at the condition of the green/yellow wire up and into the harness and it did not appear damaged. Any advice on where this green/yellow wire travels to? I had read that it goes to the fuse box inside but did not see a listing for this in the manual. Any advice on this would be appreciated! Thank You.
Noel
1999 F250LD 4X4
142k
Old 07-13-2013, 11:22 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
In a user manual page 151 look at fuses 19 and 32 in the engine bay fuse box.
Good luck.
Old 07-14-2013, 09:17 AM
Good morning thanks for the information I checked the voltage on 19 with the key on and didn't get voltage, it's listed as the trailer Stop and right turn lamp. I did not see a listing for a fuse number 32.though. Do you know where the green/ yellow wire initiates does it come directly from the fuse box to the initertia switch? Thanks
Old 07-14-2013, 10:50 AM
vaper vaper is offline
vaper is starting off with a positive reputation.
You need to look at the logic of the system
The inertia switch shuts off power to the fuel pump in case of an accident.
You have a voltage drop at the switch so it must be from the power source
(provided you had a good ground on the tester)
That is (fuse 19 in my f150),the fuel pump relay, or the circuit (wire)itself
I suspect the relay or corrosion at the fuse
good luck keep us posted
1990 f-150 4.9L no fuel. relays tested. Power to pump. pump works when hotwired. FordAnne 1987 - 1996 F150 & Larger F-Series Trucks 7 12-30-2016 12:57 PM
2004 Expedition Cranks over but won't start nyjetfan 1997-2006 Expedition & Navigator 12 09-30-2016 11:10 PM
2002 Fuel Pump Troubleshooting (intermittantly dies) cokeman Modular V10 (6.8l) 17 04-29-2016 10:38 PM
Low power to fuel pumps Bagpiper22 1987 - 1996 F150 & Larger F-Series Trucks 6 10-30-2015 12:57 PM
low voltage at inertia switch- f250 V10 no start mcmahon_66 1999 to 2016 Super Duty 7 12-25-2014 10:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
