91 f250 speedo gear removal
My speedo Is on the fritz! Sometimes it moves (not accurately) and sometimes it stays on zero. I'm assuming the drive gear is worn out, since I've replaced the driven gear, VSS, and the cable is fine. This is clearly affecting my Trans aswell. My question is, since I have the BW1345 t-case, do I have to split the case to get the drive gear out or just pull the rear yoke and seal? Anybody ever done one? My old truck had the 1356 case with the slip yoke and that had a tailshaft housing. This one does not. rear yoke bolts directly to output shaft
Thanks in advance for the help.
The following users liked this post:
itsjustagreat1
09-14-2009 11:36 PM
toycraftusa
04-03-2006 12:41 PM
nudgey
06-03-2004 08:43 PM
thomasinnevada
01-03-2003 09:09 AM
wilddog
12-21-2002 05:52 PM
