change oil after egr/oil cooler failure? - Ford Truck Enthusiasts Forums
Old 07-13-2013, 02:08 PM
JaySVX's Avatar
JaySVX JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
My oil looks good, and has 1000 miles on it. I am going to replace the screen under the oil cooler but it's in a pool of oil. I don't think any coolant got in there, but I have the oil to change in already.
My plan was to get it all together, top off with the mssing 2-3 quarts of oil, flusht he coolant, run it for an hour with distilled water, then do a coolant, oil, and oil filter change. Can I swap that screen without draining the oil? I don't have a clean container to drain the oil into to reuse for the time being. I figure there's osme crud that has gotten into the oil during the part swap.
Can I change that screen without draining hte oil?
Old 07-13-2013, 02:20 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Bud I would take a Shop Vac and Suck the HPO Reservoir out make shure theres No Junk in there
this will get any garbage out of the res
You can change the screen out either way
You will have to top off the Oil Anyways if your going to reuse it from what been lost to the work and the Bad Oil cooler
Old 07-13-2013, 02:44 PM
JaySVX's Avatar
I changed it out, I think I found the cause of my oil cooler failure too. 4 of the 6 screens had blown through.
Old 07-13-2013, 07:19 PM
BLADE35's Avatar
pull the IPR and Check its screen
You may need a IPR Screen Kit
That Old Screen looks to have chunks of Junk on it
That screen is the Final Filter before the HPO System It Didn't have anything to do with the Oil Cooler That Screen is After the Oil Cooler
Old 07-13-2013, 07:48 PM
JaySVX's Avatar
Got it. Any idea hwere I can get one at 8pm on a saturday or first thing on a sunday morning? I really don't want to wait until monday to make progress.
Old 07-13-2013, 07:58 PM
BLADE35's Avatar
SOME FORD dealers are open late
Cant see it at Oreilly auto parts
Make shure you get the Updated SS Screen
Old 07-13-2013, 08:05 PM
JaySVX's Avatar
I found a place 15 miles away that has parts hours 9-3 sunday, that's it. I'll call them tomorrow. Is there a part number i can use to eliminate any risk of getting the wrong thing?
If I pull it and it looks good, is it safe to keep using? It wasn't really chunks that you saw in the picture, more like bubbles, with a couple tiny specs.
I vacuumed the oil cooler area and it looked good, I'm hoping for the best here...
Old 07-13-2013, 08:24 PM
BLADE35's Avatar
Definatly Replace that screen your there and you have the Old Style the Newer Stainless Steel mesh screen don't rip out as easy
Didn't your oil Cooler come with it??
Maybe they don't ICR maybe I ordered mine separate
<table width="530" style="width: 398pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0" x:str=""><tbody><tr height="17" style="height: 12.9pt;"><td height="17" class="xl27" style="border-color: rgb(212, 208, 200); height: 12.9pt; background-color: transparent;">HPOP Filter Screen</td><td class="xl25" style="border-color: rgb(212, 208, 200); background-color: transparent;"></td><td class="xl25" style="border-color: rgb(212, 208, 200); background-color: transparent;">FORD=3C3Z-6C683-AB</td><td class="xl25" style="border-color: rgb(212, 208, 200); background-color: transparent;">International=1838526C2</td></tr></tbody></table>
Old 07-13-2013, 09:28 PM
JaySVX's Avatar
I got it out, but I don't see a screen anywhere. How do I take it apart? I searched and can't find anything that details it out with a diagram or schematics.
Old 07-13-2013, 11:12 PM
BLADE35's Avatar
Quote:
Originally Posted by JaySVX View Post
I got it out, but I don't see a screen anywhere. How do I take it apart? .
The Screen is stuck in the Hole the Sensor went in Be Careful and Fish it Out
the screen is at the sensor tip
3C3Z 9H529 A / 1888696C93-------------------------------------IPR Screen/O-Ring Update Kit (500 Micron)*
Old 07-13-2013, 11:36 PM
JaySVX's Avatar
Ok, suggestions on what to fish it out with? That's 2 inches deep. Screwdriver?
Old 07-14-2013, 01:03 AM
BLADE35's Avatar
You thread a screw will get it out But then its Got a Hole
some do manage to get them out without Killen it maybe small Pic or something
The Updated IPR SCreen is a Bigger Micron Rated to Clog less Easy
Old 07-14-2013, 01:15 AM
BLADE35's Avatar
Now I Always print out the Tousley Price and show my ford dealer and they are good about price Breaks
My TFT sensor was 16 bucks I think it started at 24 Bucks
this is the ipr screen below <table width="100%" align="center" style="border: 1px solid rgb(255, 255, 255);" border="0" cellspacing="0" cellpadding="5"><tbody><tr><td nowrap="">Part Num</td><td align="right">3C3Z9H529A </td></tr><tr><td>Part Name</td><td align="right">KIT - FUEL INJECTION </td></tr><tr><td>MSRP</td><td align="right">$54.00</td></tr><tr><td>Core</td><td align="right">$0.00</td></tr><tr><td>Online Price</td><td align="right">$27.92</td></tr><form name="basepart" action="index.cfm" method="get"></form><tr><td align="center" colspan="2"><input class="cartButton" type="button" value="Add to Cart"> </td></tr></tbody></table>
Old 07-14-2013, 01:22 AM
BLADE35's Avatar
Piece of Thin Wire with a HOOK
May Snag it Out without Harm
Old 07-14-2013, 03:23 PM
JaySVX's Avatar
I got int here with my pinkey, it just seemed to push back. I'm thinking a big paper clip might do hte job if I can find one big enough.
If I keep pushing it back will I lose it? I think i might have to puncture the screen to get it out. The screen feels metal but it doesn't look like it has the plastic Y on it.
When I install the new screen do I do it with the plastic Y facing out, or facing in?
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 10:33 PM
Reviewing a few things before moving on - the_auto_tech 6.0L Power Stroke Diesel 49 08-02-2013 10:38 PM
Does a complete solution kit need a HPOP h20ford 6.0L Power Stroke Diesel 7 02-08-2013 02:15 PM
Oil system upgrades/maintenance - let's get the info together! the_auto_tech 6.0L Power Stroke Diesel 55 11-22-2012 11:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
