does anyone have problems with the lock/unlock rod rattling. is there supposed to be something that holds it away from the door?
mine just viprate a make a lot of noise. any clue?
Turn down the bass?? You could try some vac line over the rod in strategic places or foam pads on the door where it hits. Be sure the clips are in good order.
