Well I didn't photoshop it but going for a straight line would have ended up in about 3" removed from the lower fender by the time you get around to the wheel opening so I wasn't going to try that. Here is the passenger side transitioned into the rollpan now.
Thanks Zoot. No plans yet. After I get the bed finished and in primer I'm going to work on the cab some more. Need to finish the hidden hinges on the doors and block sand the filler on the cab.
