Help needed ASAP
07-12-2013, 11:44 AM
on
Help needed ASAP
hi yall I have my drive shaft out on the ground in my firehouse working on my truck so I cant have this sitting in here long im trying to replace my output shaft seal on my trans. but I don't know what size the nut on the yoke is to remove it so I can replace the seal does anyone know? thanks
07-12-2013, 12:11 PM
Yipes.... I looked everywhere I could think of to try and find this information but I am coming up dry. I can't even check my own truck since mine is a 4x4 auto. Sorry man, at least this will serve as a bump for you.
07-12-2013, 12:15 PM
It may be 36mm but I can't confirm that for sure.
07-12-2013, 11:26 PM
Nate,
I seem to recall it is a 36mm. It does have a fairly thin wall IIRC.
07-13-2013, 08:47 AM
on
And they are a son of a gun to get back on!!!!! You will need to heat it up when you put the nut back on!!! I had so many headaches when I did mine! LOL
PapaMatt
07-31-2017 06:03 PM
cutlass
07-01-2017 07:24 AM
rayfinkle91
06-29-2015 09:06 PM
