53-55 f100 - eliminating window vents? - Ford Truck Enthusiasts Forums
Old 07-12-2013, 11:44 AM
Matt Black Matt Black is offline
Matt Black is starting off with a positive reputation.
I would like to eliminate my door window vents and just have one piece of glass that can roll up and down in the door. My roof is chopped 3' in the back and about 4" in the front, and I think it would look better with the window this way. I've seen pictures of trucks with this done, but when looking at my door it seems like the window would hit the door hinges. Have any of you done this mod before? Any help would be great.
Old 07-12-2013, 01:09 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Note that the window channel with vent is curved, not straight. Mid Fifty Home - Mid Fifty F-100 Parts sells a one piece curved glass replacement kit, but don't know if the glass will work with your chopped top. Other alternative is to straighten the door channel for flat glass (Mid Fifty also sells a kit for this, but it requires some significant body work to the doors. The hinge area inside the door does require some modification as well and is detailed in the kit instructions.
Old 07-12-2013, 01:42 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
you can see the MF one piece kit install in my gallery.
the glass is cured both ways, and probably couldn't be cut.
Old 07-12-2013, 03:17 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is online now
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
I've got the same issue that you have. I've received a couple examples from other builders on the window issue. You might try looking at this link to see what this guy did. I think the window info starts around thread #40. Maybe it will give you something to consider.
Chopped 55 f100 - The Garage Journal Board
I'll have to look to find the other example.
Old 07-13-2013, 09:48 AM
Thanks guys! I can't seem to find the kits you mentioned on midfifty.com. Does someone have the link? The kit install looks pretty straight forward thanks to sdetweil.
The other option that I'm considering is to make the vent window a fixed window. I just hate the rubber seal under that pivot and I'm really trying to clean up the look of the door. This route my window glass stays the same even with the chop, and the mods to perma-mount the vent window would be less extensive.
Old 07-13-2013, 01:25 PM
sdetweil's Avatar
the one piece kits from the 53-55 slantcabs are on page 98 of the pdf catalog. their online pdf is at http://midfifty.com/images/2012_Midfifty_Catalog.pdf
Power windows and power door locks advice Bojohnson 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-27-2016 06:39 PM
Rt vent window handle, what part breaks? annaleigh 1968-2013 Full Size Vans 1 05-06-2016 06:51 AM
56 side window ...conversion to one piece design. ulev1st 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 03-13-2014 10:23 AM
Vent window delete? DirtyCustoms 1967 - 1972 F-100 & Larger F-Series Trucks 13 04-21-2012 08:36 AM
How do I eliminate the vent windows? GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-15-2002 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
