1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Parts Help
Old 07-11-2013, 07:21 PM
TruBlu61's Avatar
TruBlu61
TruBlu61 is offline
Parts Help
I have a few miscellaneous parts that I need for my 61 unibody and could use some help with parts numbers if anyone has the time and resource to look them up. I have found a number of these parts as reproductions but would prefer to try and locate some NOS if possible.
Drivers side door arm rest
Mirror extension arm (round mirror on door)
Dome light lense and housing
Turn signal lever
Radio antenna
Window crank ****
Inside door handle
Battery hold down clamps and hardware
Shifting lever **** (3 on the tree)
Glove box liner
Thanks in advance.
Old 07-12-2013, 11:46 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Drivers side door arm rest The color is?
Mirror extension arm (round mirror on door) Only sold with mirror.
Dome light lens and housing
Turn signal lever
Radio antenna
Window crank **** Only sold with crank handle.
Inside door handle
Shift lever **** (3 on the tree) Have fun installing it!
Glove box liner
You want the info...you'll have to call me ( I p/m'd # to you), as I'm not typing 10 +/- part numbers, then listing all the sources that have them NOS
Old 09-15-2013, 11:29 AM
jasch's Avatar
jasch
jasch is offline
Need parts
Turn signal lever
Radio antenna
Window crank ****
Inside door handle
Glove box liner
Thanks in advance.
I too have just purchased a 62. I have numerous parts that I need.
Side Mirrors
Turn Signal Lever
Sun Visors
Horn
Dome Light (complete)
Door Locks (My Doors lock, however, I have no key lock to get into truck once it is locked)
Seat belts
Dual Master Cylinder (brakes)
Rear bumper ??
These are just a few of the items and I only know of Dennis Carpenter Reproductions, however, could not find everything.
Thank you to anyone that can help me out!!
Old 09-18-2013, 10:47 PM
69supercj's Avatar
69supercj
69supercj is offline
I've got the dome light and I've also got the horn(s) if your talking about the ones that mount on the core support and not the steering wheel horn button. Also have the sunvisors, door handle and window crank.
jgavac
07-30-2017 08:38 PM
Tow Mater 62
03-14-2015 02:42 PM
fordman75
06-09-2014 09:21 AM
SuperDuty93
07-20-2013 10:40 AM
civicmindeddogooder
10-31-2010 03:20 PM
Quick Reply: Parts Help
