99 Exped Front Blower Problem
Allright I need help please.
I have a 99 Expedition Eddie Bauer 5.4 4x4 383k miles.
All of a sudden the front blower stopped working on any setting. Read through the forums and decided I needed to replace the Blower Motor Resistor. While I was in there, I wanted to avoid going back in, and replaced the blower also. Plugged everything in, and ZIP, nothing, nada!
Swapped relays around under the drivers side (relay 5 for 4, they apparently are the same). Swapped 2 for 1 and still ZIP! Checked all of the fuses (there is a 40) under the hood that relate to the front blower. Anyone have an idea of how to test the plug (3 wires) going into the resistor? I guess the last thing to replace is the EATC head.
Grab your meter and check for power on both blower motor connection pins (leave motor plugged in) with the system turned on. What are the two voltage readings?
The wire that alloro referred is an orange wire that runs from pin 17 of the EATC to the low side of the blower relay. If it's indeedburned up, the blower will never operate.
YOur vehicle doesn't have a resistor pack, it uses an EATC-controlled blower Control Module to operate the blower, assuming that the blower motor relay is operating correctly.
So I checked the voltage after the new resistor I installed from Autozone, which sits under the glove compartment and has 1 connector coming in and 1 going out to the blower fan.
Voltage red to vehicle ground = none detected
Voltage black to vehicle found = none detected
EATC unit on with vacuum sounds at the selection of different modes. Fan selected high (and every other position also).
So do I understand this correctly that I solder a jumper wire from the yellow/brown wire that plugs into block 1 (which goes to the round fan control) the other end is (flat 5 pins) to Pin 17 which is right behind the black male plug on the logic board where the 2 plugs to the vehicle plug in.
I hope this makes sense...
Bill
Bill
I mean inside of the EATC unit. Trace the circuit starting at the #17 pin the orange wire connects to, and continue to follow it onto the copper clad PC board inside the EATC unit. You could also first test this orange wire for power when the blower is supposed to be on. If this wire is without power the problem is inside the EATC unit, if the wire has power the problem is not with the EATC unit.
Wait a minute.
If you have an EATC, you have a BCM, not a resisitor module. If you have a manual control, then you have a resistor pack.
Try doing it the right way: Black lead to ground and red lead to pin 17. Unless directed otherwise, always put the black lead to ground when making voltage checks.
Been fixing electronics stuff for 35 years... This is just another application of those accumulated repair jobs. Having the Ford service docs also helps.
Tested with my voltmeter on 20v black to the #17 dot, and red on the flat rotary connector to the fan rheostat
I'm fascinated - how in the world do you guys know all this?
Part Number: JA1704.
I have also replaced the blower motor with a new one. Found a used EATC for 90.00 with a 30 day return policy. With any luck, that will fix it.
Thanks so much for all your help, you all are the best!
Bill
DKW 86
10-05-2010 03:02 PM
