Replacing body panels - Ford Truck Enthusiasts Forums
Old 07-11-2013, 10:08 AM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
I am replacing outer sheet metal along the left side of my 65 Econoline van (lower portion between fenders, rear fender, and rear corner with fuel filler).
I would like to know if anyone has any advice or warnings before I tear into this.
I have already removed the rear corner and repaired the floor and rear door jamb. Before going further, I would like to know if I'm going to run into any structural problems with too many pieces removed.
Thanks
Old 09-25-2013, 09:16 PM
scoobyvanjack scoobyvanjack is offline
scoobyvanjack is starting off with a positive reputation.
Did you get it done? How did it go? I found a bunch of internal ribs that ran from the roof to the bottom of the rocker. I made boxes that mimicked the originals. Inside the left rear corner my fuel filler tube was in a box that needed some patches. under the body I found an odd corner reinforcement though welded in it was also bolted in.
These were on both sides but the right one was completely gone. Had replaced the rt corner first and didn't even know it was missing. I ran into trouble scabbing in panels along the top of the wheel wells and the more so the ones that butt up to it on the upper panels above. I'm going to cut them out and try to spot weld a thicker strap of steel along the edge to arrest the metal from warping. The door jamb is made up of a lot of various details and boxes and channels these add a lot of strength to the hinge point. I've posted a few picks on one or two spots to see. Good luck with yours I'm getting near the end of the sheet metal and will need to grind the welds smooth and fill it smooth. I'm gonna try my hand at lead but if need be it I'll finish it in Bondo.
Cab Corner Cowl replacement Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-03-2014 01:09 PM
55 F100 Rear Fender Bolt Removal DGMFORD 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-11-2013 10:47 AM
cab corner brace F100man 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 06-12-2013 07:20 AM
Fender welting before or after fender install? ranger pat 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-05-2004 01:41 PM
Best patch panel source? Fat Fendered Ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-22-2002 01:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
