Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
engine swap needs help
Old 07-11-2013, 02:55 AM
Brian Thacker's Avatar
Brian Thacker
Brian Thacker is offline
Will a 1994 5.0 out of a f150 work in a 1990 f150. Wiring harness is different and distributor is different. Can I put the 1990 distributor into the 94 engine?
Old 07-11-2013, 07:26 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Welcome to FTE Brian! Unfortunately I can't help you on this one. Hopefully someone out there can help you.
You might want to post in this forum: Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
Or here: 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
xphr8r
06-22-2016 05:16 AM
tatonka
11-03-2013 07:16 PM
1990-f250
07-09-2013 08:26 PM
1990-f250
06-28-2013 10:32 AM
sledneck988
1978 - 1996 Big Bronco
12-04-2008 06:00 AM
Quick Reply: engine swap needs help
