engine swap needs help - Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
Old 07-11-2013, 03:55 AM
Brian Thacker Brian Thacker is offline
Brian Thacker is starting off with a positive reputation.
Will a 1994 5.0 out of a f150 work in a 1990 f150. Wiring harness is different and distributor is different. Can I put the 1990 distributor into the 94 engine?
Old 07-11-2013, 08:26 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Welcome to FTE Brian! Unfortunately I can't help you on this one. Hopefully someone out there can help you.
You might want to post in this forum: Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
Or here: 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
engine swap alternator differences 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 20 03-29-2014 01:46 PM
Distributor cast iron or steel gear?? tonkyman 1987 - 1996 F150 & Larger F-Series Trucks 8 07-18-2013 09:31 PM
Removing and installing a Distributor B Dobz 1987 - 1996 F150 & Larger F-Series Trucks 28 06-25-2012 06:46 PM
Identifying Distributor gears karnut03 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 11-26-2003 04:29 PM
Distributor cap diagram dwpenney Ford Inline Six, 200, 250, 4.9L / 300 6 01-10-2003 07:27 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
