water coolant temperature sensor
I am trying to replace the water temp sensor "housing" not the sensor, but the little do dad that it screws in to. The do dad or housing screws in to the engine and has a half inch hose coming off the bottom and the sensor screws in to it and then the electric wire hooks to the sensor. The housing which is off with the sensor still attached developed a hole and started leaking causing my van to overheat. I took the entire unit to the only part store that was open and he said he did not know what the unit was called that the sensor in screwed in to. My van is a 1996 aerostar 3.0 I have searched the internet and can only find the sensor, but not the thing that it screws in to
I would just assume that if it has a hole in it, it must have corroded through, no other reason it should have a hole in it.
There is a thermostat housing, however that is the part that holds the thermostat in place and it has no sensors in it. So its not the part you need. On the 4.0L the part you need is part of the lower intake manifold, but its been a while since I worked on a 3.0L. I'm not sure what it would be called.
I know its not available aftermarket because when you pull up every cooling system part in an aftermarket website like Rockauto.com, the part you need is not listed. They show the thermostat housing, which is not what you need based on your description.
Ok all you experts..I found the part on my own by making one phone call to a ford dealer auto part counter..I explained what it was I needed and within a couple of mins. he found the part...are you ready for what it is called???
Hot water elbow!!! It houses the engine coolant temperature sensor and yes it is an after market part and price was $24.40
phoneman91
09-11-2011 03:20 AM
demarpaint
07-20-2005 10:39 AM
