Replacing cam bearings
Old 08-03-2013, 07:39 PM
angrymade's Avatar
angrymade
angrymade is offline
Hello all,
I have somehow found myself on an engine building adventure. It all started when my oil pump seized due to a piece of broken valve stem seal that made it past the oil pump pick-up screen.
It's a 68' 429, in my 66' F100. Since I pulled the motor to install a new pump I decided to throw in a new cam. Today I pulled the cam to find all of my cam bearings are heavily scored and literally falling apart.
To make what could be an extremely long story short I'll get to the point.
Have any of you had to have new cam bearings installed? Did you have to tear the block completely down? (pull crank and pistons) And what was the rough cost?
Thank you in advance.
Jesse
Old 08-03-2013, 08:55 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
What do the rest of the bearings look like?
I would pull it down and do a rebuild as long as you are that far into it.
Where did all the material from those bearings go? Through the other bearings at some point!!
Old 08-03-2013, 11:59 PM
angrymade's Avatar
angrymade
85e,
I had been thinking the same thing. I am going to just pull the rest of the motor apart and start from scratch. Thank you for the input.
Jesse
rpatrick
06-16-2011 08:06 AM
66shortbed
04-08-2010 01:53 PM
newblder
08-07-2008 08:47 AM
bikerwolfie
05-21-2002 05:51 PM
FE427TP
05-10-2001 04:52 AM
Quick Reply: Replacing cam bearings
