sas q?s
sas q?s
helo I have a 94 f150 and going to put in a 44 straight axel and I have a 6 inch in it already can I use my springs with a the older axel and also can I use by drop radius arm brackets from the original axel
ps. I have a 5 speed and was going to run 35s and would like to know the gearing to get me back to stock or closest to stock to get best mpgs with the bigger tires thanks hope to get positive feed back oh I new on here and names derrick
Yes you should be able to use your lift springs. I'm not sure on the drop brackets for the radius arms though, but I'd assume you could manage to get those to work.
With 35" tires, no matter what you have for a motor you should be running at least 4.11 gears. If you have a 5.0 you might want to go with 4.56 gears to keep torque up.
dale gribble
03-31-2006 09:47 AM
