Oil Pan Gasket Issue - Ford Truck Enthusiasts Forums
Old 07-10-2013, 05:53 PM
78fourby4f250 78fourby4f250 is offline
78fourby4f250 is starting off with a positive reputation.
Ok I have a 460 and I just bought a Ford Racing one piece rubber oil pan gasket. Was getting ready to start threading in bolts and noticed that the 2 bolts on front and back would not go in. I took it down and noticed that the 2 bolt holes on front and back were same size as the rest and not bigger.
Has anyone else ever run into this issue? I figured I would buy a pretty decent gasket instead of just a cheapie one. Spent 26.00 on this gasket from Ford Racing and I figured everything would be good.
I was going to try to drill out the holes a little bigger since they have the metal reinforcement but I didn't want to end up damaging it in case I have to return it. I cant put smaller bolts in there cause then they wont thread into the holes in the block.
Any thoughts?
Old 07-11-2013, 08:41 AM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
I just had the same issue on a motor I am building. Got the rear sump pan and it came with the one piece gasket. I ended up drilling the pan to to 21/64" and drilling the inserts in the gasket as well. Be careful when drilling the gasket, use a sharp bit and don't use too much pressure. Also doesn't hurt to use a cutting oil to keep the bit and insert cool.
Old 08-03-2013, 12:29 AM
BigBlockF350's Avatar
BigBlockF350 BigBlockF350 is online now
BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.
I just used the same gasket on a 1971 block. You need to drill out the gasket for the corner bolts. Be careful doing it or you can mess up the rubber around it. Also don't let it heat up too much while drilling or it may burn the rubber. This is standard procedure. I believe all pre-79 460s have the larger corner bolts.
Also, incase you're interested... The steel core in my gasket didn't want to lay completely flat on the pan (because of shipping I'm guessing), so I ended up using some Indian Head high tack gasket glue (can get it at most auto parts stores, it's a little brown bottle) on the pan. Then I stuck the gasket to it and put the pan upside down and put some weight (an old 8lb flex plate) on the pan and let it sit there for about 4 hours. The gasket was stuck fully to the pan after that, and I bolted it right up to the engine. That'll also help keep the gasket to stick only to the pan if I ever need to pull it off again, and hopefully it won't stick to the block.
Old 08-03-2013, 01:05 AM
Yeah thanks that's what I did I used a little cutting fluid on a drill bit with the drill press and cut em bigger. Went smooth didn't get hot and drill bit didn't catch. Got oil pan put up with no problems
Thanks again
Old 08-03-2013, 07:41 PM
Quote:
Thanks again
Sure thing. Glad you got it done right!
1995 300 I6 oil pan gasket change DIY DAT2109 1987 - 1996 F150 & Larger F-Series Trucks 1 07-11-2015 10:36 PM
Bolt not threading in block - Tap and Die ?s Finger__Rachet 1987 - 1996 F150 & Larger F-Series Trucks 3 07-06-2013 07:07 PM
1998 F150 OIL PAN LEAK robjs111 1997 - 2003 F150 5 04-01-2011 09:19 PM
460 Rear sump Oil pan/Ford Racing #$%@!!! dman2008 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 03-31-2009 03:01 PM
Oil pan gasket woes (long post) rog_j Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 18 06-23-2004 12:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
