oil filter - Ford Truck Enthusiasts Forums
oil filter
Old 07-09-2013, 08:21 PM
obscurity's Avatar
obscurity obscurity is offline
obscurity is starting off with a positive reputation.
oil filter
Does anyone know if there is a cartridge style over-the-counter oil filter that will work in a 239 flathead?
Old 07-09-2013, 08:31 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
NAPA # 1006. I have also used #1004 in a pinch. They are good quality WIX filters.
Old 07-12-2013, 12:16 AM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
In a super pinch fram C4.........at orileys.
Old 07-12-2013, 09:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Since oil filters were an option back then, are you asking for the cartridge oil filter element (6731) only, or a complete cartridge oil filter assembly?
Old 07-12-2013, 12:39 PM
obscurity's Avatar
I think I just need the cartridge element. The engine has most everything else in your illustration. I have thought about adding a spin on conversion but at least in the short term I am looking for a cartridge element I can use without having to mail-order it.
Old 07-12-2013, 12:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The filter element is as described by Tinman, NAPA stocks them. The filter system does not lend itself to using a spin-on because it only filters 5% or so of the oil pumped by the engine, and gravity drains to the oil pan. There are ways to convert to a modern 95% filtration system with remote spin-on element, but they require complete engine disassembly and modification.
Old 07-13-2013, 12:12 AM
EAK69's Avatar
EAK69 EAK69 is offline
EAK69 is starting off with a positive reputation.
Quote:
Where did the pic come from (book, online, manual, etc)?
Old 07-13-2013, 02:21 AM
ALBUQ F-1's Avatar
postin' fool
Quote:
Parts CD, 1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
Old 07-13-2013, 01:16 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Fram C4
WIX 51006
Purolator P34
Napa 1006
Motocraft FL25
Oil filter for rotella 15w-40 standardtransonly Oil & Lubrication 12 12-26-2015 02:14 PM
Oil filter lewis racing 6.0L Power Stroke Diesel 10 08-22-2014 10:50 PM
Larger Oil Filter Fleetsuper 1999 to 2016 Super Duty 19 06-15-2014 06:44 PM
Oil and Filters Teds 6.0L Power Stroke Diesel 20 02-08-2012 06:20 PM
oil filter adapter Marvin A 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-04-2002 10:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
