rear blocks 78 f250 4wd need help
Hello,
I have a 78 f250 4wd and I am missing the factory rear blocks. I am ordering new springs and require the 3 inch block for total height.
Rich, (77&79f20) has two different blocks.
Part # DOTA 5729-A , 2" 1/8 wide 4" 1/2 long and 3" tall.
part # D3TA 57298A??? 3"wide x 4 1/2 x 3" tall
The 3" wide block does not have a pin for the spring perch. Just two 9/16 holes. Can anyone confirm which block I need and/or which block they are using? If anyone has the block with two holes, what are you using to center the block on the perch? stud of some type?
I currently have 2 inch wide blocks and it just does not look right.
Thank you
CHris
Thank you
CHris
CountryBumkin
05-28-2017 04:19 PM
Mr7.50headsup
09-26-2014 11:00 AM
houstonstroker
1999 to 2016 Super Duty
17
07-29-2013 02:23 PM
