Think your accel pedal position sensors bad? Think again. - Ford Truck Enthusiasts Forums
Old 07-09-2013, 06:45 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
So about 5 months ago I was getting major buck and dead spots on my throttle pedal and engine check lights. All sorts of fun. So assuming that my a.p.p. sensor or as most ppl cal them "TPS" was bad , I head to napa buy a new one. Well it lasted about a month. Then the same thing occured. It took me 3 tries with three different sensors. Junker dorman brand. So I took them in on warranty about 3 times and finally said I'd had enough. Luckily I kept my stock ford motorcraft sensor. So what I did was eliminated the IVS from the system. I removed it off the pedal assembly and mounted it right under the dash. So it is sort of an anti theft device also in a way. Because you can start the truck. But there's no throttle response until you find the switch and click it once. I've had it this way about 2 months. And its working great ! My truck is my daily driver. No problems at all. No buck. No check engine lights. Nothing. I'm planning on posting pics of the mod soon. But if nobody cares ill just leave the words to describe it no pics. I also forgot to mention that the throttle is smoother now then when I bought the bugger.
Old 07-09-2013, 06:57 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I always bend the IVS tab in closer to the IVS so that the magnet hits the tab quicker/easier. I just bend it close enough so the switch hits as soon as I move the pedal just a tiny bit.
Glad you got it working. Never heard of anyone doing this before. Well done.
Old 07-09-2013, 10:40 PM
DanielT28's Avatar
Well I just figure I didn't want to mess with the tuning. & I didn't know where the tab was. Inginuity
Old 07-09-2013, 11:32 PM
Its a metal tab on the pedal. No biggy. You got it done another way. Lol
Old 07-09-2013, 11:53 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
That's just a mechanical switch, not a magnet. Works like a brake light switch, or the light in the fridge. Tab that hits the plunger is right on the pedal arm; adjustment takes but a minute. But the "limp mode" idea is intriguing....
Old 07-10-2013, 12:45 AM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
A pretty clever idea! I like it!
Old 07-10-2013, 06:32 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
How does moving the ivs fix dead spots in the tps ?
Old 07-10-2013, 10:47 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
sounds like the tps wasn't the problem to begin with, rather that the ivs was going in and out for some reason while driving. I imagine that would cause some serious bucking!
Old 07-10-2013, 02:45 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Just keep in mind that you have also defeated what is considered to be a safety feature. If your TPS were to go bad now, the truck would run away. It's probably not a huge deal for someone who knows the truck, but that switch is intended as a fail safe to override the TPS signal when you aren't pressing the pedal.
If it were me, I think I would just replace the IVS. They're not more than $20. If you wanted the "anti-theft" feature of it you could still do that by interrupting the signal to the IVS with a single pole switch and hiding it under the dash somewhere.
Old 07-10-2013, 02:59 PM
^ Good point, Nate.
take away the IVS and you might as well call it a Toyota! ok, maybe that's a little extreme (any highly offensive) :-)
Old 07-10-2013, 10:04 PM
DanielT28's Avatar
They don't sell the ivs separately do they ? I read once upon a time to fab up your own. Idk how to
Old 07-10-2013, 10:29 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
They do sell the IVS separately if you can find them. May have to go to Ford dealer.
Old 07-11-2013, 07:58 AM
Yeah, they do. The IVS is a Cutler Hammer Part # SS22BW32-330Y. It used to be an in-stock part at this site: SS22BW32-330Y Cutler Hammer/Eaton | Buy SS22BW32 330Y | Onlinecomponents.com. I'm not sure if they can still get them (they show that they have 0 in stock) or if you can locate one somewhere else.
Old 08-02-2013, 05:24 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
subscribed
Old 08-06-2013, 02:38 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
sorry to bring last week thread up, seems silly to start a new one.
would this fix, bucking at slow speeds, low throttle input? like crawling around a drive thru? my wife almost spilled her ice cream last night cause the truck lurched forward with very little throttle pressure. its only the second time its happened. thanks
Need several OBDII PID's from a 2005-2006 Expedition or Navigator please! AGrayson84 1997-2006 Expedition & Navigator 0 11-08-2016 02:56 PM
Replaced Accellerator Pedal Assy & Nothing Farmer_Jack_13 1999 - 2003 7.3L Power Stroke Diesel 3 10-24-2016 12:26 PM
Adjustable Throttle Pedal IVS, TPS HACK! Why spend $800? Oldguyfl Excursion - King of SUVs 2 09-22-2016 06:29 PM
Throttle Position Sensor goes bad every 6 months or sooner BigRedWeather 1994.5 - 1997 7.3L Power Stroke Diesel 19 09-04-2016 06:56 AM
3.0 Duratech DOHC Bucking Problem mtnlovrs 3.0L V6 2 10-27-2011 05:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
