Think your accel pedal position sensors bad? Think again. - Page 5 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #61
Old 07-18-2014, 12:14 AM
LeoJr's Avatar
LeoJr LeoJr is offline
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
How often do you have to hit the IVS, every time you let off the throttle and then back on? Or just the first time each start up? Or are you making it a non-momentary switch?
  #62
Old 07-18-2014, 12:25 AM
powerstoked!'s Avatar
powerstoked! powerstoked! is offline
powerstoked! is starting off with a positive reputation.
another cure
Fyi gents, I replaced my old dead battery with a new optima red top 34 and recharged my older optima back to good as new. Problem completely went away.
So if you're having this APP/IVS problem, a good first place to start would be pulling your batteries and load testing them. Apparently normal operation with just one unhealthy battery will Drop system voltage or sensor output sufficiently for the system to create these same problems we are seeing with the APP sensor and IVS issues.
  #63
Old 07-18-2014, 01:39 AM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
You just start the truck. And click it one time. That's all. Other guys were saying that if something were to go haywire with the TPS the truck could take off. But I haven't had a single problem. And if that were to happen all is have to do is click the switch and hold it. Or put it in neutral ANd kill it
  #64
Old 07-18-2014, 12:57 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
Quote:
It's amazing to me how many people don't think of this. kind of like the "runaway" Prius a few years ago....whatever...ever heard of neutral?
On another note, I have had mine off the pedal for a year now. Best mod ever next to E-Fuel.
  #65
Old 07-19-2014, 12:54 AM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
Can someone point out the tab to bend to eliminate the dead band prior to the click? Im at work but im gunna do this when i get home in a couple weeks. That pedal movement prior to any revs always annoyed me.. Thanks!
  #66
Old 07-19-2014, 02:38 PM
Quote:
I'd just remove it. I tried the tab bend thingy and had to do it a few times to get it good, but it was never perfect. I finally just gave up and took it off and then relocated it under the dash. It's good anti-theft and the driveability was like a new truck.
  #67
Old 07-19-2014, 03:00 PM
Quote:
I hear ya.. I dunno.. I think I'd like to try and bend the tab first.. The thing is I have no idea what it looks like.. Can someone post a pic of the said "tab"?
  #68
Old 07-19-2014, 03:30 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
Its the tab in the middle of the pedal assembly. It is connected to a switch with a white button.
An even better solution is to convert over to the SD accelerator pedal. Action is so smooth and not having the IVS click(that is super loud) is amazing.
  #69
Old 07-19-2014, 05:30 PM
Is there a write up on this? I thought not having the IVS was slightly dangerous?
  #70
Old 07-19-2014, 06:02 PM
As far as I know I'm the only one to have ever done it.
They have an internal IVS.
  #71
Old 07-19-2014, 06:29 PM
Gotcha. Do you have any tips or tricks for the install?
  #72
Old 07-19-2014, 06:37 PM
Of the SD pedal?
  #73
Old 07-19-2014, 07:17 PM
Of the SD pedal?
Yeah. Does it bolt up? With the different body style I'd think it'd be different.. What'd u do w the wiring Specifically?
  #74
Old 07-19-2014, 08:49 PM
I would like to know as well. I had no idea the SD pedal would work. Do tell.
  #75
Old 02-26-2015, 08:51 PM
pgerblonski pgerblonski is offline
pgerblonski is starting off with a positive reputation.
alas another dead thread...
i've been fighting what appears to be an IVS issue for some time (i'm just that ornery that i've fiddled with the pedal to start it for over a year, rather than researching what was actually wrong... not bright i suppose, but...)
anyway, it seems there are no NEW IVS's available - that i can find so, it seems that i won't be doing the simple replace...
not wild about simply jerking it out (tempting as it may be)
apparently we're left with Fabbing/creatively swapping another switch in... or what seems to be suggested here about the possibility of swapping to the "new" SD pedal setup...
... and then the thread went dead
what happened?
help?
Need several OBDII PID's from a 2005-2006 Expedition or Navigator please! AGrayson84 Expedition & Navigator 0 11-08-2016 03:56 PM
Adjustable Throttle Pedal IVS, TPS HACK! Why spend $800? Oldguyfl Excursion - King of SUVs 2 09-22-2016 07:29 PM
Throttle Position Sensor goes bad every 6 months or sooner BigRedWeather 1994.5 - 1997 7.3L Power Stroke Diesel 19 09-04-2016 07:56 AM
Intermittent failing pedal..idle only acf6 6.0L Power Stroke Diesel 225 02-02-2015 07:50 PM
97 Powerstroke throttle position sensor lhaley45 1987 - 1996 F150 & Larger F-Series Trucks 1 03-21-2009 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
