Think your accel pedal position sensors bad? Think again. - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-06-2013, 07:27 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
For me it's honestly a lot smoother. Because before my truck would do the same thing as that. I like it better
Old 08-07-2013, 04:50 PM
21411 21411 is offline
21411 is starting off with a positive reputation.
thanks ill have to put that on the shopping list
Old 08-07-2013, 09:33 PM
mjunk1's Avatar
mjunk1 mjunk1 is offline
mjunk1 is gaining momentum as a positive member of FTE.mjunk1 is gaining momentum as a positive member of FTE.
This is interesting. What I get is a buck at about 45-50 when you are just lightly feathering the throttle. I'm guessing after reading here and the other thread going by Byron that mine is the adjustment on the TPS. You open the throttle a little and the fuel doesn't get there as fast as the air so you get a stumble... I guess.
As to the single pole switch, I found a mystery switch on my truck at RRE and it was hidden in behind the fuse panel. Flick it off and you get all the lights but no start. I think it is wired into the ignition switch.
Finally, spilling your wife's ice-cream is a serious no-no, so you better nip that in the bud!!! lol
Old 08-08-2013, 06:16 PM
DanielT28's Avatar
The buck I had was right at the beginning of the motion. It was rediculous because as soon as it clicked the ivs it was like whip lash. I had enough.
Old 08-09-2013, 12:16 PM
Quote:
if looks could kill! (i can hose her off, that cloth bench would be stained forever!)
Old 08-24-2013, 02:17 PM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
So,to be clear, you are not using the IVS at all? I have a new one on the way, but have been having absolute hell with this and it won't be here until Monday. I replaced the TPS twice...same problem. I then got another CEL and no throttle. I took the IVS off and the truck runs fine...better in fact! Is there any harm in removing it or just letting it hang? I can't take the buck anymore either. It is about the drive me crazy!
Old 08-28-2013, 07:04 PM
DanielT28's Avatar
ive had mine this way for about 2 months I guess. not 1 single issue yet and its my daily driver. all I did was mount it with a sheet metal screw right about where my brake controller for my trailer is. works awesome and im pleased.
Old 08-28-2013, 08:07 PM
91 Dually 91 Dually is offline
91 Dually is gaining momentum as a positive member of FTE.91 Dually is gaining momentum as a positive member of FTE.
Ok, let me get this straight. I believe I have read on here in other posts that you can remove the IVS, but you have to activate it at east once after you start the truck each time or you get no response from the throttle. Is this correct?
Old 10-21-2013, 10:14 PM
DanielT28's Avatar
THats completely correct
Old 10-21-2013, 11:35 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
If you have to activate it once, you can't remove it. You can relocate it as stated above. But you disable a safety feature in the process.
Old 10-21-2013, 11:57 PM
DanielT28's Avatar
You can push the button down anytime and hold it and it'll cancel out the signal the tps sends. But that's also correct
Old 10-22-2013, 10:39 AM
Unless you other IVS wiring issues like I do. I am getting them worked out though.
  #28
Old 10-22-2013, 10:38 PM
Hogtrapper's Avatar
Hogtrapper Hogtrapper is offline
Hogtrapper is starting off with a positive reputation.
Gentlemen, I hope this is not considered a thread hyjack because that's certainly not my intention, please accept my apology if I am in the wrong. Can anyone tell me what an IVS is? I am working on a '97 model 250 that is having the same type issues as described in this thread. The sensor mounted on the throttle pedal, not sure what it's called, is spring loaded like an old wind up alarm clock. I can only find one sensor under the dash on the pedal assembly. In the last 10 months there have been 4 of these sensors installed and now the last one has gone bad, well the same symptoms have returned anyway. Do all 7.3s have TPS and/or IVS or what? This is ALL new to me and I thank you for your input and again I apologize if this is considered a thread hyjack.
  #29
Old 10-22-2013, 11:05 PM
There's a sensor and a switch. All the OBS PSDs (not all 7.3s) have both. The sensor is basically a "volume ****", a variable resistor. The spring is just the pedal return mechanism. The sensor connector has three wires; the switch connector has two. The switch works like a fridge door switch; closes as soon as you move the pedal and the little tab moves away from the plunger.
  #30
Old 10-23-2013, 09:38 PM
Hogtrapper's Avatar
Thank you mad, I appreciate it. I'm not sure which way to turn but I do know a little more now. If I may ask another question please. I can only find one "sensor" under the dash on the pedal assembly. Is there any type of "accelerator"/"throttle" sensor under the hood of a '97 F250 7.3? Thank you again for your help.
Need several OBDII PID's from a 2005-2006 Expedition or Navigator please! AGrayson84 1997-2006 Expedition & Navigator 0 11-08-2016 03:56 PM
Replaced Accellerator Pedal Assy & Nothing Farmer_Jack_13 1999 - 2003 7.3L Power Stroke Diesel 3 10-24-2016 01:26 PM
Adjustable Throttle Pedal IVS, TPS HACK! Why spend $800? Oldguyfl Excursion - King of SUVs 2 09-22-2016 07:29 PM
Throttle Position Sensor goes bad every 6 months or sooner BigRedWeather 1994.5 - 1997 7.3L Power Stroke Diesel 19 09-04-2016 07:56 AM
p0221 Service engine soon Riversonly 1999 - 2003 7.3L Power Stroke Diesel 14 03-01-2015 06:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
