2003 Explorer Eddie Bauer 4.0l SOHC Timing chain cover gasket change
I have seen several threads on this but I need a little more information before I attempt it. I have a 2003 Eddie Bauer explorer with the 4.0L SOHC . I have a coolant leak from the passenger side that is not a water pump issue.
When removing the timing chain cover with the engine in the car, do I need to remove any accessories ( power steering , alternator etc. ) or their brackets?
Not sure how to close a thread on here or if it is even possible.
Fortunately I have discovered I do need to remove the timing chain cover to fix a water leak. Through the use of a boroscope I eventually discovered the leak was from a failed ultrasonic weld on the backside of he thermostat. Housing. The leak was dripping down the passenger side of the timing chain cover, appearing to be leaking from the cover
Take a close look at your tensioners when you are in there. Proven POS design. You have to pull the engine to get the back one.
As for your thread, don't worry. 6 years from now, someone will pop up and answer your question for you......
This forum has a lot of picture-rich threads specific to the Exploder.
You can find a blow-by-blow on several things 4.0 SOHC related in the prior generation threads.
Stock 2002 - 2005 Explorers - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
terry274
09-09-2017 06:44 PM
F3fitty
05-08-2011 03:41 PM
MGMKDM
02-02-2008 08:24 PM
Babcore
07-12-2003 05:55 PM
